#2491 |
New heated Grip fitted to the bike, don't want a cold hand in the cold weather!
Nice and straight forward to fit, and not too fiddly (unusual for BMW) |
#2492 | |
#2493 |
I did some more welding on the tank i'm making. Unfortunately the wind picked up and the gas ran out so I didn't get as much done as planned, but for only the 3rd time tig welding I'm happy and learning as I go.
#2494 |
It does feel good to me on the bike now, and the foot pegs feel better than when the tank was shorter so that's a win. I have just worked out an articulated front fairing bracket that will give approx. 25mm of up and down movement and tilt forward and aft. That will let me bolt it on and move it around till I'm happy.
#2495 |
Trying to work out what's wrong with the VFR. Took it for MOT yesterday and it passed. On the way home charging dropped and then lost all power.
I've recently done a reg rec upgrqade and hard wired it all in. Double checked it all tonight and all connections seem good. No problems with the stator on a static test. Reg rec readings are all as should be. Wiring I put in is all showing good continuity etc and getting voltage reading from the battery at the reg rec end. Looks like I have more to investigate tomorrow. Not sure where to go from here though. Possibly pull the stator cover and check it out visually? It's not showing going to ground or any bad connections though. I think resistance is within Honda spec. I need to double check that though. Possibly with it hot too (remembering the DRZ problems I had with running heat puttting up the stator resistance until it was out of spec.) Currently only getting 11.7 volts at the battery when it's running though. All was fine a couple of weeks ago apart from dirty connectors and hesitant cranking when cold.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... Last edited by Adam Ef; 09-11-21 at 10:52 PM. |
#2496 |
I'm not good with electrickery but I think that's a very wise thing to check, just in case a component somewhere is being heat- or load-sensitive.
#2497 |
Odd that I'm getting 11.7v back even when cold though.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
#2498 | |
John T
#2499 |
Do you know what replacement you went for? I'm tempted to look for another RM Stator one if I need to swap it out, but they're expensive. If there's something as good for less then I'd opt for that instead.
+ What mileage did you have on yours when you did it John?
#2500 |
Checked again today and the voltage output from the stator running was non-existent.
Opened it up and I'm going to just bite the bullet and swap it for a good new RM Stator one. Probably a new battery too as it's dropping a bit low when cranking and has shown signs of problems for a while. ![]() ![]()
