Old 19-12-21, 09:05 AM   #2561
gt alex
Default Re: What have you tinkered with today?
Here's the fiat 126p. They were sold here as a FSM Niki, mine is a Australia only prototype with no roof or doors.
Only 2 were made I bought this one I bought from a wrecker yard about 15years ago and I just found out the other one has just been found after storage since 2009. I will post a picture soon
gt alex is offline   Reply With Quote
Old 19-12-21, 09:32 AM   #2562
gt alex
I have reached my attachment limit how do remove some from memory.
I would appreciate some advice thanks
Old 19-12-21, 12:44 PM   #2563
you need to use a hosting site like https://postimages.org/
Old 19-12-21, 07:27 PM   #2564
svenrico
svenrico's Avatar
How does this then transfer an image to this site if we can't just attach an image from our computer ?!
ps yes I am a Luddite.
svenrico is offline   Reply With Quote
Old 19-12-21, 07:31 PM   #2565
DJ123
DJ123's Avatar
reply; go advanced
At the top you see a yellow box with a mountain(?) inside. Click that and paste in the URL to the picture you uploaded.
Submit reply/preview post and you'll see the picture links in
BMW F800ST
Old 19-12-21, 07:43 PM   #2566
svenrico
svenrico's Avatar
Originally Posted by DJ123 View Post
reply; go advanced
But if I am trying to post a photo I took it won't have a URL will it ?
Old 19-12-21, 07:44 PM   #2567
DJ123
DJ123's Avatar
No, you have to upload it to a sharing site, such as the one Bib's shared.
BMW F800ST
Old 19-12-21, 08:46 PM   #2568
gadget
i would put the usb charger on a "ignition switched" relay.. you can use something like the side light as the trigger for the coil side. just make sure that its the feed side of the sidelight coz if the bulb blows you loose power to the relay. get a fused relay or any inline fuse will do. ooohh and 3 amp is plenty.
Top man, many thanks for the info. Having said that.. I've also got the option of using a dedicated motorcycle cigarette style charger I've had forever! My current satnav uses this type and I can use one of those USB plug in things if I need to charge then phone!!? What would be a suitable fuse rating for a cigarette style charger?
gadget is offline   Reply With Quote
Old 19-12-21, 09:18 PM   #2569
look at how many amps the charger puts out, that might give you a clue. tbh i personally would not bother with a fuse.
Old 19-12-21, 10:07 PM   #2570
ok i'll try my best to explain with some pretty pictures
go to https://postimages.org/
then choose your image size:
press the choose image button:
browse to where your image/pic is on your computer:
click on the image/pic then press the open button, your image will start to upload:
once uploaded choose the "direct Link:" icon on the right hand side. this will copy the link to your clipboard:
go to the thread on here that you want to post the picture in and press the box with the mountain in:
a pop up window will appear, right click in the box and choose paste from the drop down menu, then click ok:
if all has gone well you should have the postimage direct link pasted between [IMG]pastedlink[IMG], if you do then press reply.
top tip. when writing a reply you do all the above where you want the image to be like i have done above. good luck and if you have any questions just ask.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
