Old 16-11-14, 06:29 PM   #261
NTECUK
NTECUK's Avatar
Default Re: What have you tinkered with today?
Decorated the boys room.
Old 16-11-14, 07:02 PM   #262
Fruity-ya-ya
Scrapped what was left of the clutch cover gasket off and cleaned the emulsified oil off ready for reinstallation.
Although I couldn't get the plate off to wipe the oil filler window clean (killed x2 allen keys trying).
Old 16-11-14, 07:19 PM   #263
Buy some good allan head sockets
Old 16-11-14, 07:32 PM   #264
Fruity-ya-ya
Default Re: Re: What have you tinkered with today?
Yup. Father Christmas might get an email after today.
Old 16-11-14, 07:45 PM   #265
pookie
pookie's Avatar
testing diy amblight system with lightpack.. its a disco here
Old 16-11-14, 11:34 PM   #266
Doinitmyway
Doinitmyway's Avatar
Been sorting out the fuel leak on my Aprilia today, common fault so I've been told. Not nice having fuel ****ing out near the hot exhaust
https://www.facebook.com/photo.php?f...4&l=7e07526d30
Chris
10 GSX650F
95 BMW Funduro
89 FZR250R (x2)
92 RG80 (x2!)
89 AR125 - 89 RG125
75 CB200
Doinitmyway is offline   Reply With Quote
Old 17-11-14, 12:32 PM   #267
Corny Gizmo
Originally Posted by SV_archie99 View Post
Took lots of pictures during the process, so will do a bit of a write up.
Please do, I need to do mine soon
Old 17-11-14, 02:01 PM   #268
shiftin_gear98
shiftin_gear98's Avatar
Built a summer house - yep prefect time of year.
Got it for the kids to call home, just need to get their bunk bed to fit in now....
Currently driving a Corsa....
Old 18-11-14, 08:52 PM   #269
SV_archie99
Draft write up nearly done, should be uploaded in the next couple of days.
Old 23-11-14, 06:49 PM   #270
Fruity-ya-ya
Replaced my Gladius license plate bulb.
I cannot believe just how convoluted it was, almost took as long as swapping out my clutch basket!
Remove seat.
Remove side panels (or as I did just pulled the x2 clips near the rear and left the panels on I've fitted crash bungs that i had to drill the side covers so I remove them only when absolutely necessary).
Remove back-box/pillion handles (x4).
Remove U shaped slip on cover.
Disconnect seat lock cable.
Disconnect indicator connector clips left & right, tail light connector & license plate bulb clips & feed the cables out of the ties etc.
Unscrew license plate (x2).
Unscrew under fender cover (x1).
Unbolt rear assembly (x4) and remove.
Unscrew both indicators (x2) and fish cables.
Unscrew bottom screws (x2) holding cover on (or in my case unscrew x1 & drill out the rusted one, then re-tap and hunt for a replacement screw).
Unbolt the license plate bulb assembly/reflector (x2).
Undo the screws holding the lens on (x2).
Unscrew the bulb, swear loudly before getting in the car to go to Halfords as you've picked up the wrong one yesterday then buy a pack of 207S 12v 5w (if this is the wrong bulb I'll hunt down that sales clerk), drive home & replace the bulb.
Then just do it all again backwards (barring driving to Halfords & drilling the screw) remembering to reroute the cables & clips as you go.
Simples.
Maybe time for a tail tidy!
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
