Old 05-02-17, 06:17 PM   #2731
Kenzie
Kenzie's Avatar
No, still waiting. Will give him until Wednesday and pop him over an email. I did find while rummaging in my crates if many cameras a Yashica 50mm f1.9 DSB lens if you are interested? Its not multi-coated like the ML but is in one piece. Not shot with it yet. Picked it up while hunting for a 50mm ML to replace the one I sent you.
Old 05-02-17, 07:48 PM   #2732
yokohama
Don't worry about another lens Kenzie. The 50mm you sent me is fine; it's got character. The glass is clear and it works; skylight screws on and stays on now. The plan is to put a Poundland test roll through it.
Old 05-02-17, 09:05 PM   #2733
Kenzie
Kenzie's Avatar
Character, I guess that is one way of putting it. Going to use Fomapan 100 to cut down to fit the Minolta 16, will have to wait unti l have some 127 backing paper.
Managed to score a Paterson Universal 3 tank from the UK for £12.99 inc postage. Just need some film now to cut down.
Old 06-02-17, 06:20 PM   #2734
johnnyrod
johnnyrod's Avatar
AAARGH well I won the focus screen but in the last 10 mins I decided to look around to see if I was sure it was the right one. The answer is no, it's too big, but I won it anyway. Hm will have to identify it and sell it on. While looking around though, I found the right one:
http://www.ebay.co.uk/itm/Vintage-Ce...-/252757021449
Can you believe it? Nothing then two at once. So will double check later and get a bid on.
Old 06-02-17, 06:37 PM   #2735
Kenzie
Kenzie's Avatar
Did you win the plates?
Sent from my Xperia
Old 06-02-17, 10:00 PM   #2736
johnnyrod
johnnyrod's Avatar
They're up later in the week. That one includes the 6x4.5 mask so I do want it. Will end up with loads of plates if I get both, but can sell some on.
Old 06-02-17, 10:04 PM   #2737
Kenzie
Kenzie's Avatar
Ah, so you want to make it a half frame then. Will you use the plates or are you just after the masks?
Old 06-02-17, 10:20 PM   #2738
johnnyrod
johnnyrod's Avatar
Doubt I'll use the plates, it's more for completeness, I do want to try 645 so it's a good opportunity. Also not to waste a chance, these bits hardly ever come up, so it's even more surprising to find two. I do a search for "certo" from time to time, worldwide.
Old 07-02-17, 09:28 PM   #2739
Kenzie
Kenzie's Avatar
Still not had my lens through. Any joy with yours Yoko?
Old 07-02-17, 09:29 PM   #2740
Kenzie
Kenzie's Avatar
