21-10-23, 01:47 PM | #2751 |
John T
Re: What have you tinkered with today?
Following Craig's recommendation, I popped over to the Honda centre and bought some FS365. That's now slapped all over the vulnerable parts. Got a pair of gloves from the bargain bin too.
Sent from my moto g(50) using Tapatalk
21-10-23, 08:04 PM | #2752 | |
As mentioned before, when you come to wash the bike, give it a quick pre-misting of the FS and it makes cleaning really easy. |
22-10-23, 08:46 AM | #2753 |
John T
That was my plan. I think I dismissed FS365 in the past because it washes off whereas AC50 is more resilient but does leave a residue. Kevin Jones , who started this site, used to spray WD40 on his SV which did stop the corrosion but it turned hard on his engine casings and was hard to remove.
23-10-23, 01:52 PM | #2754 |
After just about ten years of procrastination I finally took out the rear brake torque arm, cleaned it up, and shimmed it to remove the small amount of lateral play at the base end. Looking at it, I can see that, despite me bushing it, the hole in the torque arm is a bit elongated now, so I think it's actually time for a new one.
23-10-23, 02:08 PM | #2755 | |
John T
23-10-23, 02:12 PM | #2756 |
I shall probably do the same when I get a new torque arm.
23-10-23, 02:54 PM | #2757 |
That's one improvement the Gen 2 / Gen 3 bikes have, the rear caliper is above the disk and held on a alloy casting that slots onto a tongue on the swingarm, so no torque arm needed and it attracts a lot less crud (not that I ever use the rear brake anyway)
23-10-23, 04:03 PM | #2758 | |
I actually prefer the torque arm arrangement. Refitting the rear wheel axle whilst persuading the caliper/alloy carrier assembly to not drop out of position and let the the pads fall off the shelf they sit on, is a pain. I take the silencer off and it's still a pain. There will be blood and curses, many curses. I use the back brake all the time, a habit left over from drum brake era perhaps and mediocre SV front brake (on mine at least).
2016 SV650AL7 2023 GSX-8S |
30-10-23, 05:31 PM | #2759 | |
John T
I noticed the silencer was a bit loose whilst cleaning. The clamp needed a good tighten. I have complained to Honda and the factory worker concerned has committed Hari-Kari. Sent from my SM-T510 using Tapatalk
06-11-23, 08:19 AM | #2760 |
Dug out one of my bicycles from the temporary pallet shed where it's been stored for the last year. Gave it a clean and a bit of a service ready for a ride with a friend in Dyfnant forest tomorrow. I need to have a tinker with the gears sometime today.
