Old 03-10-24, 01:06 PM   #2801
garynortheast
garynortheast's Avatar
Default Re: What have you tinkered with today?
Originally Posted by R1ffR4ff View Post
Hope you don't mind but I like to hear what parts ( not consumables) on High-Mileage bikes that may have had to been replaced over the years if you would
Brake and clutch levers twice, reg/rec once, starter solenoid relay once. All the rest have just been standard consumables.
Old 03-10-24, 01:15 PM   #2802
R1ffR4ff
R1ffR4ff's Avatar
Great
That's a testament to a well made and well serviced machine
On my 99 coming up to 40k I've had to change the R/R and have changed the Starter relay as it was getting old. I put a foldable gear lever on just in case the bike gets dropped on the left to help prevent clutch damage,
I also had to ditch the original Brake Master cylinder as that went. I went with a Brembo style round one from David Silvers as I've used them on my old Hondas and I hate those M/C screws <grin>
https://www.davidsilverspares.co.uk/...R/part_123885/
Old 03-10-24, 01:25 PM   #2803
garynortheast
Actually, just remembered I fitted a foldable rear brake lever about 13 years ago after I fell off and broke the original, and also replaced all the original engine case screws with a set of s/s socket heads.
Old 03-10-24, 04:26 PM   #2804
garynortheast
Oil and filter change done.
I then went on to tweak the chain tension and had water dripping out of the end of the swingarm. Took the adjuster screws and end caps off, cleaned out the inside and unblocked the drain holes on the underside ends of the swingarm, then squirted ACF50 inside.
The last job is ongoing. I've been using a biodegradable chainsaw oil in my Scottoiler and while it lubes the chain ok, it forms a black, baked on skin of oil on the sprocket and outside of the plates on the chain. I've spent the last 2 hours trying to clean it off with paraffin, a toothbrush, and elbow grease! I haven't finished yet.....
Old 03-10-24, 05:36 PM   #2805
Sir Trev
Sir Trev's Avatar
You've reminded me Gary. Now I have a bike I may use on nice days over the colder months (instead of hibernating for the best part of six months) I need to get some ACF50. A job for Saturday, assuming I can find somewhere apart from Amazon that stocks it of course.
Old 03-10-24, 05:50 PM   #2806
garynortheast
I normally just do an ebay search Trevor.
Lots of choices here.
Old 04-10-24, 02:31 PM   #2807
garynortheast
Bike now cleaned and slathered in ACF50. I'm almost afraid to ride it now in case I get it dirty. The engine is very quiet again after an oil and filter change.
Old 04-10-24, 02:40 PM   #2808
Craig380
Looking good, Gary!
Old 04-10-24, 07:27 PM   #2809
garynortheast
She scrubs up well for a scuffed old girl doesn't she Craig?
Old 05-10-24, 10:24 AM   #2810
R1ffR4ff
R1ffR4ff's Avatar
Can't beat fresh engine oil It always make s the engine feel good IME. I think it was someone on here who put me onto"Smith and Allen" oils,
https://www.smithandallan.com/produc...cycle-oil-4117
I love that it's a full gallon so does 2 oil changes and delivered to my door at an honest price. I use their Fork-oil as well now,
https://www.smithandallan.com/produc...k-oil-15w-4114
I use HiFlo filters as above but the ones with the 17mm Take-off as it makes taking them of a doddle,
https://shorturl.at/FNtUu
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
