Old 13-06-13, 12:50 PM   #2941
Owenski
Default Re: The Cycling Thread
"busy"
Old 13-06-13, 01:04 PM   #2942
Luckypants
Luckypants's Avatar
Default Re: Re: The Cycling Thread
Originally Posted by Owenski View Post
"busy"
Sent from my phone.
Old 13-06-13, 09:32 PM   #2943
smudga
Default The Cycling Thread
I went & did 16 miles on my bish today got to my turn around point & the heavens opened up
looked like a drowned rat when I squelched back in lol
Old 21-06-13, 08:58 AM   #2944
Owenski
again!
ANOTHER busted inner tube
Thats 4 in 3 months! I wouldn't be so annoyed if it were just a puncture that a patch would fix but its always a nip on the tubs from the ****ty road surfaces on my commute.
The roads are broken up near the channels and in the heavy traffic its unreasonable to ride in the middle of the lane. 9 times out of 10 I dodge the worst ones but every now and then I get caught out and like today wake up to find a flat tyre waiting to great me.
Anyone any suggestions?
Old 21-06-13, 09:16 AM   #2945
Yes 2 suggestions.
What tyres are you using? Nothing is completely puncture proof, but Continental Gatorskinz are almost, plus from what I've been reading Vitorria tyres are also very good.
Also this nip in the tube, is by chance on the underside of the tube? There's a trend for wheelmakers to use plastic rim tape, now under certain circumstances the rim tape can move or shift causing the inner tube to go into the spoke hole and find a sharp piece of metal that wasn't cleaned off in the finishing process.
So if by chance the hole is on the under side (ie rim side) then fit some proper Veloflex cloth rim tape. Smooth any sharp spoke ends or spoke holes.
http://www.wiggle.co.uk/velox-rim-tape/
Old 21-06-13, 09:48 AM   #2946
pookie
pookie's Avatar
I've also seen slime tubes but not sure how effective they will be.
Old 21-06-13, 11:17 AM   #2947
There are better sealants out there than slime tubes. This one got great reviews, but you have to apply it yourself.
http://www.merlincycles.com/bike-sho...FTMgtAodTFAA3Q
But I don't like the extra weight the sealant adds to the rotating mass of the wheel, and I don't use slime tubes or anything similar. I don't suffer many punctures.
Old 21-06-13, 11:31 AM   #2948
Owenski
You're not the first one to recommend those gatorskins actually so I will give that a go.
Wiggle have them on a full set 2 tyres 2 tube offer so I'm going to have a piece of that thank you.
Old 21-06-13, 11:35 AM   #2949
They are expensive, but I've not hard any punctures on mine.
I've seen a GP4000 with a sidewall cut from a flint, but its not the same construction as a Gatorskin.
When you replace the tyres, have a good look at the rim tape, make sure its seated properly in the right place
Old 21-06-13, 11:41 AM   #2950
Roberrrrt
linky?
Oi, no cycling on my pavements! northwind Idle Banter 21 23-04-09 03:24 PM
Cycling to work MCN_LiamM Idle Banter 19 01-11-08 08:48 AM
The cycling thread! rob13 Idle Banter 11 27-08-08 02:00 PM
So what did I do to deserve this ( warning cycling based thread ) fizzwheel Idle Banter 45 16-07-08 11:05 AM
Cycling to France pencil shavings Idle Banter 2 18-03-08 12:28 AM
