#21 |
there are the main 20amp fuse down by one of the side panels near the seat, i cannot recall what side of the bike it is?
it could also be the starter switch? I have done big jobs before only to have something else fail (side stand switch) half way though, un known untill I had ripped the bike to pieces again. |
#22 |
You talking about the one in the starter relay... the 30 amp ones, there fine else I would have no dash lights.
#23 | |
The Sick Man
have you rocked the bike back and forwards in gear and then try to start again, to see if the starter is dodgy?
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#24 |
i seee..
been a few yrs since I had me one of them fangled SV things... |
#25 |
#26 |
The Sick Man
Missed that bit in the original post.
#27 |
I think its just going to be strip it down and have a look again...
One thing though... from the connections to the carb heater there are 2 more connections below there. Just single lines. I think one is the oil pressure switch, and the other I can't remember or be sure if I have them round the right way... Anyone able to advise? |
#28 | |
The Sick Man
#29 |
Definitely not the immobiliser from the Meta alarm... Wouldn't be able to turn it over if it was.
I've got a loose connection somewhere on my bike, which sometimes causes erratic backfires and then not being able to start it. Try wiggling the wires going into the ignition unit under the pillion seat, that seems to fix it for me. That might give you an idea to which is loose (if indeed it is a loose connection). Have you got a spark at the front? |
#30 |
I need to take the front apart to check that so never did, it was easier to check the back. Though if I had a spark at the front it should run, as I've had it running on one cylinder before.
swapping battery with GSX600F | Terence | SV Talk, Tuning & Tweaking | 3 | 10-07-07 09:33 PM |
Swapping Radiators | squirrel_hunter | Bikes - Talk & Issues | 9 | 13-05-07 02:38 PM |
swapping batteries | redeye321 | SV Talk, Tuning & Tweaking | 2 | 29-11-06 08:24 PM |
Swapping headlight bulbs | Jase22 | SV Talk, Tuning & Tweaking | 11 | 21-12-05 12:33 AM |
Swapping the exhaust | mysteryjimbo | SV Talk, Tuning & Tweaking | 2 | 06-10-04 10:48 PM |
