#21 |
The PCB uses the electrode to pass a current through the flame. The ionization in the flame creates a path for the current. If the electrode isn't properly in the flame, current won't flow and the PCB will shut the gas off. As already mentioned, the electrode could be burnt, so too short to reach the flame, or the electrode is out of position, so not in the flame, or the flame has moved, so not on the electrode. Is the electrode visible when in use?
#23 |
Dad reckons it may be the thermo couple?
Sent from my magical portable device
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold 2012 Street Triple R - For Sale - Linky here |
#24 |
Evel Knievel
That's what my old man said with his over the phone diagnosis but all the error code point towards the flame detection electrode.
personally I don't need heating and I'd leave it broken, but I have one of those nagging voices that tells me to do stuff around the house. |
#25 |
Dad's are always right with their remote problem solving.
#26 |
Im sure the electrode just bolts in from the front once the inner case is off. Just a crap Allen head bolt holding it in
#28 |
If the system has both forms of flame detection, then a faulty thermocouple could cause the gas valve to shut and the other detection system wouldn't see a flame, so give that error message. So could be a faulty thermocouple if the system has one.
When you did the continuity check were you checking between the disconnected electrode and earth? If so, it sounds as though the electrode, or its wiring/insulation is shorting to earth. A new electrode assembly should cure that. |
#29 |
No thermocouple on these boilers, they're far to cheap and reliable to be on modern boilers
![]() Its a fixed shape so can only go in one way. Ive never pulled the fan ect to change an electrode on these. |
#30 |
Evel Knievel
might it be worth pulling it apart to clean off the burner?
I've just been flicking back through the book and it's never been serviced. It was installed in 2008. BTW only bought the place in Feb so it's not my fault. |
old crap boiler - help please! | johnnyrod | Idle Banter | 6 | 24-12-10 07:27 PM |
Boiler issues! | MisterTommyH | Idle Banter | 9 | 10-12-10 01:31 PM |
Is this boiler any good? | BoltonSte | Idle Banter | 20 | 12-01-10 01:39 PM |
Another Boiler Problem! | DarrenSV650S | Idle Banter | 11 | 05-01-10 06:55 PM |
gas boiler has gone | steveg | Idle Banter | 14 | 06-10-07 10:46 AM |
