Old 13-01-08, 09:30 PM   #21
Lozzo
Default Re: Paraffin - Bloomin' great stuff!
if you think paraffin is impressive you should try brake cleaner
Brake cleaner swells the O-rings on chains causing them to split. Not recommended.
Old 13-01-08, 09:46 PM   #22
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
the can i have says "brake and chain cleaner" - made by Wurth
i thought the whole point of brake cleaner was that it specifically didn't kill your piston o-rings...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 13-01-08, 10:00 PM   #23
Lozzo
The material used for brake piston seals is different to the material used for chain O-rings. There are a number of different types of rubber used as seals depending on what purpose they have or what fluid or lubricant is being used. Brake cleaner may be fine on brake seals, but I know for a fact it swells chain O-rings because I experimented on an old chain. You'd be surprised at just how much they swell and how easy they break afterwards.
Old 13-01-08, 10:09 PM   #24
the_lone_wolf
Captain Awesome
i guess there must be different cleaning fluids, as this is what i use...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 14-01-08, 11:26 PM   #25
-Ralph-
I wouldn't bother now with the hosing down as you've covered the chain in lube anyway and that'll protect any paraffin that may be remaining. I'm sure it'll be ok, it's just a precaution rinsing off the paraffin, plus it rinses off any remaining gritty bits that the brush may have missed. Hopefully.
+1, parrafin won't damage your o' rings, you could take the chain off and submerge it in parrafin to clean it if you could be bothered. Rinsing off grit is the main reason for the water.
Old 14-01-08, 11:31 PM   #26
Ask alpinestarhero how many solvents there are
They've just found one thats safe with both types (unless it isnt actually safe..), at the expense of dissolving slightly fewer materials.
Old 15-01-08, 01:55 AM   #27
phil24_7
I wonder..... If I mixed all these solvents, would they get me high quicker!!
Old 15-01-08, 01:37 PM   #28
Carb cleaner is pretty much all the make-you-go-blind-and-mad solvents mixed together
Old 15-01-08, 02:08 PM   #29
John Burt
Parafin is perfectly safe to use to clean chains and does not require washing off on completion, I'd be a little wary of using brake/carb cleaner permanently though.
Bloomin NHS Shellywoozle Idle Banter 20 24-11-08 10:23 PM
Paraffin cleaning question skyline SV Talk, Tuning & Tweaking 20 14-10-08 04:15 PM
Where can i buy paraffin doe SV Talk, Tuning & Tweaking 10 06-04-06 09:21 PM
BLOOMIN' BRAKES!!! coombest SV Talk, Tuning & Tweaking 12 18-02-06 04:19 PM
At last... i bloomin did it! Anonymous Idle Banter 7 02-02-06 09:37 AM
