#21 |
Just Ballast
The handbook does say what Robo says, but we check it cold, can't really see it makes a lot of difference as long as you do check it.
If It's Too Loud, You're Too Old! I'd Rather Have Two Big Bangs Than Four Little Strokes |
#22 |
#23 |
you do it cold so you get a more accurate level. When your oil is warm its travelled round the system a bit, and may seem low when you check it. If you top it up, and go back to it I garantee it'll say you'vr over filled it above the high level mark.........trust me I got told off by Im Indoors for doing a check after I'd run it a little. I'll do as I'm old in future!!
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
#24 |
Cool, thanks everyone! - gotta go now.
Will silicone the bolts in the morning, and change oil for nice new oil. |
#25 |
#26 |
mine was leaking a few weeks ago - turned out to be the crank case breather pipe.
#27 |
Thats a common one too, but if you look in his pic you can see that the oil spill does no go high enough which means a leak is coming from either the clutch or the water pump. Always go to the oil marks highest spot and work down.
#28 |
OK lets stir things up a bit..............................
![]() I do know the answer to my question, but would like to see how many of you spend too much cash !!!! Why BIKE OIL ONLY ? why not a bit of old api spec sl 10/40 car oil ? As you can generally buy a 5 litre can for the same as 1 litre of "bike oil" Discuss........................................... ........................................ |
#29 |
The leak your referring to is the waterpump. There are 4 seals in total.
There is an o ring seal inside the waterpump, when this fails water/oil mix will leak from the casing. This is currently happening on mine (although not as bad) and its going in to be fixed Thursday. Your probably getting a little bit of water in your oil, that will explain the creamy stuff. I would get the leak fixed properly first before replacing it. As for silicone on the nuts???? - This will only be a temporary fix and its just hiding the problem. |
#30 |
I was referring to the clutch cover which is a seperate piece on the early curvy's and a well known problem. They only way it can be treated properly is to replace the side casing with a one piece casing as used on later curvys and pointys.
'99 SV650 curvey for sale | zobo | For Sale - SV's and SV related items | 3 | 05-10-07 02:18 PM |
SV650 - curvey | darrens_here | Stuff Wanted | 5 | 23-04-07 06:26 PM |
Curvy SV650 clutch cover oil leak | bugsy46 | Bikes - Talk & Issues | 1 | 06-04-07 11:28 PM |
SV650 Curvey Headlight | MattP | Stuff Wanted | 6 | 13-07-06 12:19 PM |
Not oil leak - Petrol leak - double "Bugger"...! | Potts | SV Talk, Tuning & Tweaking | 1 | 17-10-04 08:16 PM |
