#21 |
Silly question, but did you check with the engine at running temperature? At cold you shouldnt see any oil at all in the glass when bike is level. And also when you said the oil is black, it should be oil coloured, not black. I'd mebbe try a flush.
#22 |
The oil is nice and golden colour as i changed the oil and the filter for new yesterday. i then ran the bike in idle for 6 or 7 mins then left it to settle and it was just below the full mark when i checked after letting it cool.
#23 | |
Cold oil will still move around, and will still show in the sight glass, it's not 50w mineral oil in winter you know...
#24 |
The Suzuki manual states that oil level should be checked with the engine at operating temperature. Tilting a cold bike off the sidestand to level it up and checking the oil level is not a good idea. Whether you see oil in the glass or not is irrevelent, in my bike, you dont if you do that, after running, it shows near max. After the oil has leveled up, fair enough you should see some.
#25 |
So why is there a different amount of oil in there when warm? (expansion yadda yadda, but that's negligble on the sort of dT involved in this...)
Seeing oil in the glass is the only clue you get as to whether there's oil in the motor or not, what are you going to do on a rebuild... run it for 5 minutes only to discover that actually there was nothing in sump?
#26 | |
As for a rebuild, you simply completely drain and add the volume of oil specified by the manufacturer for that engine. |
#27 |
Right then so why does the bike being hot affect gravity? Angle of sidestand makes no difference as oil is checked with bike upright. Viscosity is also fairly unimportant as it may take an extra half second to reach an equilibrium level cold, but it's still going to be the same level as when hot.
#28 | |
#29 |
It says to check warm, not check when it's just been switched off and the oil is mostly not in the sump. That takes a bit of time to get back to bottom.
#30 |
Right, for the record, i was talking b@lls. Just checked. Cold bike on stand - nothing in glass. Cold bike held upright for a few secs - site glass showing overfill, full to top. Just running bike to get up to temp now and i guess when warm it'll drop to max. Doh, guesss i've glanced at full glass before and as its full you dont see the meniscus line. My bad.
Can fork oil be topped up ?? | Stormspiel | SV Talk, Tuning & Tweaking | 6 | 20-06-05 03:01 PM |
