Old 10-11-08, 01:20 PM   #21
Stig
Default Re: contact lenses
Thanks for your post Hovis.
I am about to go to the opticians myself as I managed to lose my glasses. Have considered contacts before and now I think I will definitely give them a try.
These trial for a month ones. I assume the are prescribed lenses and not just 'blank' ones?
Old 10-11-08, 01:21 PM   #22
454697819
Specsavers Lenses for 3 years now if not more...
Been fantastic, £13ppm - through the door every 3 months, best thing I ever did, to the point I now want laser surgery, but cost is too much.
My eyes to stream a bit on the bike but that could be the helmet or the speed...
Old 10-11-08, 01:23 PM   #23
It also depends on what sort of prescription you need too. I haven't worn them for a while. I think there still is a cut off to how strong your prescription(or complicated) befoer they can't make them for you. I know that my prescription was the last extreme before they couldn't offer me them. -.3.75 amongst other things, now I have a -4.25 and its doubtful I could have them TBH, unless things have changed
And APe, they aren't blanks that they give you to trial
Old 10-11-08, 01:30 PM   #24
Stig
Thank you.
Old 10-11-08, 01:35 PM   #25
RichT
It'll depend on the make(s) of lens the optician carries. We manufacture most of ours to +/-8.00 and some to +/-10.00. It also depends if you have an astigmatism. In this case you will need a toric lens which incorporates a cylinder value as well. On higher wear freq lenses this stops around -2.25, but there are lenses (typically made to order) that go to +/-20.00 with a cyl of about -5.00.
I'm a +4.25/-2.25x162 in my left for example (blind as a bat)... Unless the individual can't get on with lenses, you should be able to find your perscription.
Old 10-11-08, 01:36 PM   #26
hovis
the price as also put me off a bit, i guess your looking at £150 a year?
but my last glasses i paid £180 for, and that was less then a year ago, and they are a bit out of shape now,
Old 10-11-08, 01:37 PM   #27
keithd
glasses frames come in and out of fashion, you're face will never go out of fashion Hove. think of it that way
Old 10-11-08, 01:38 PM   #28
hovis
are you flirting with me?
Old 10-11-08, 01:42 PM   #29
[quote]=rthoms;1681255]. It also depends if you have an astigmatism. In this case you will need a toric lens which incorporates a cylinder value as well. On higher wear freq lenses this stops around -2.25, but there are lenses (typically made to order) that go to +/-20.00 with a cyl of about -5.00.
[quote]
Yes I an astigmatism in one eye, and yes I had the toric lenses, but the dodgy eye didn't like them after a while. I'm as blind as a bat in that eye, lets just say a fly in the good eye riding a bike is always errrr interesting with either specs or lenses....especially lenses
Old 10-11-08, 01:43 PM   #30
keithd
do you want me to flirt with you?
contact lenses part II (how much£) hovis Idle Banter 19 08-12-08 04:03 PM
Daysoft contact lenses slark01 Idle Banter 5 25-11-08 10:25 AM
Use contact lenses? Carl Idle Banter 28 07-06-08 05:36 PM
Please help me contact Skippy xlewdx Idle Banter 2 14-12-06 04:07 PM
contact lenses pegasus Idle Banter 28 16-07-06 08:27 PM
