Old 11-05-09, 02:30 PM   #21
Ceri JC
Default Re: Damaged fork oil seals, checking cause.
Originally Posted by AndyBrad View Post
what do the seals look like? pitting can cause a seal to fail easily. Is it running through the seal under max travel? or at all? alternativly it could be being damaged on assembly. other thourghts are that the sanctions are bent pulling the seal out of round over a period of time. Lastly are they getting contaminated? whats the dust seal like? and are you packing 2 much grease around them on assembly preventing the seal from energising properly?
In total I've done this 3 times (and it has leaked each time), in the following order;
1. Reused original OE seals that had been on the bike since new, 4.5 years old.
2. New Aftermarket seals (from wemoto, IIRC).
3. New OE seals.
In none of the instances has the seals appeared visibly damaged. In terms of there being too much rubber grease, I wiped the excess off so am confident it's not that. I think the dust seals are new OE ones (fitted recently), but I'll check this later.
No reason to believe the stanchions are bent, not least because one of them is a new one (old one had more serious pitting, so I replaced it whilst I had the forks out last time).
Old 11-05-09, 04:49 PM   #22
punyXpress
punyXpress's Avatar
You haven't been putting too much oil in ?
Now: Street Triple R
Old 11-05-09, 09:56 PM   #23
Ceri JC
Nope, exactly as specificed in the fork internals' manual (around 17cm from the top). I measured it using a special fork oil depth guage/syringe so know it was spot on.
Fork oil seals, which way up? Ceri JC SV Talk, Tuning & Tweaking 5 04-03-09 07:33 PM
Fork Seals. Grinch SV Talk, Tuning & Tweaking 7 24-05-07 11:45 AM
Fork seals have gone JakeRS SV Talk, Tuning & Tweaking 3 23-07-06 12:29 PM
fork seals ruff_ryder SV Talk, Tuning & Tweaking 11 29-06-05 05:43 PM
Fork Seals and Oil R11ysf SV Talk, Tuning & Tweaking 1 11-03-05 10:46 AM
