Old 24-03-09, 09:29 PM   #21
arcdef
Default Re: Whats wrong now!!!!!
It did need alot of choke to start, not sure what you mean by returning?
Old 24-03-09, 09:41 PM   #22
punyXpress
punyXpress's Avatar
When you pushed the lever back ( you did, didn't you ? ) the choke went off?
Now: Street Triple R
Old 24-03-09, 09:48 PM   #23
arcdef
yeah that's when it cut out.
Old 25-03-09, 07:06 AM   #24
Red Herring
Red Herring's Avatar
Sounds like a fuelling issue to me. Is the tank venting properly, check the vent hole and pipe for obstruction (or just open the cap). Whilst at it check the overflow and breather pipes from the carbs, sometimes the bottoms get blocked with chain lube/road muck. Is the air filter clean and unobstructed? Finally how clean is the tank (inside). Perhaps as you got down to the dregs it sucked up some debris. Check the fuel line from the tank for blockage (not sure on an SV, sometimes there is a little gauze filter on the tank pickup).
Old 25-03-09, 11:59 AM   #25
arcdef
Default Re: Rough running and noise.
Well i have spark and they are in good condition, tbh i have no idea what to look for when it comes to leaks, the air box was secure but have no way of balancing the carbs.
Next up i guess i better check the fuel system.
Old 25-03-09, 12:46 PM   #26
AndyBrad
what do the plugs look like?
Old 25-03-09, 12:46 PM   #27
Caddy2000
Would I be right in thinking that each carb has it's own filter (in the body of the carb), is it possible for one of these to have become blocked and therefore leave the bike on one cylinder?
Old 25-03-09, 01:30 PM   #28
arcdef
well despite the petrol light only just beginning to flash it seems after some fresh petrol it started much easier but still sounded rough. Im guessing it has sucked some debris in somewhere but dont have a clue where to start looking .
Oh and the plugs looked new as id expect!
Old 25-03-09, 01:55 PM   #29
chris8886
chris8886's Avatar
did your rev counter just stop working and go down to nothing but the engine was still running, despite being rough?
AR08 to AR13-QUALITY!
Old 25-03-09, 03:37 PM   #30
pod
Water in carbs, drain float bowls.
rough running ? mikey devon SV Talk, Tuning & Tweaking 11 21-03-09 12:07 AM
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
Rough running after several months off :( Gasman SV Talk, Tuning & Tweaking 3 23-12-05 07:17 AM
