#21 |
Good job you haven't sold the Virago yet
#22 |
Following on from tazdaz's reply, do you "blip" the throttle on downchanges to reduce the risk of the rear tyre loosing grip?
Inspect for any oil leaks, chain lube fling onto the rear ture etc. You say the problem also happens during cornering - is it more prominent through either left turns or right turns? I'm going with tyre pressures at this stage, but there could be a slim chance its the rear shock. How old is the bike, and its milage? |
#23 |
waiting for mate with tpg
it might just be me but right turns are really scary 15000 on the bike its a 99 |
#24 |
taken into account the weather? not being funny here - we've some good dry spells followed by a load of rain - this will make the roads very greasy.
Silver SV650SK3, Fuel exhaust |
#25 |
Check the right side of both tyres. Check the rear brake is not binding aswell? With those miles and that age, the rear shock will be a bit tired but shouldn't be giving those problems, I'd think you can rule it out
#26 | |
How do you spin the wheel in the direction of travel ( which is what I think you are impying ) when the throttle is shut and no fuel is being admited to cylinders to burn to move the bike forward. Cant see what you're getting at...
#27 | |
#28 | ||
If you're hooning down the road, apply the front brake so the weight is on the front, but at the same time knock it down a few gears which will cause the revs to shoot up. Won't this cause the rear to try and spin quicker than the front??? ![]() |
#29 |
If it is just happening on right handers I'd check the wheels are aligned as has been already said.
#30 | |
The engine braking can overcome the rear wheel and lock it up though, as editted. As has been stated, I'd look at head bearings, tyre pressures, and all the swingarm pivots. Last edited by sam anon; 04-05-09 at 07:19 PM. |
Fish (not food!) | pencil shavings | Idle Banter | 17 | 19-10-08 05:11 PM |
fish and chips | AndyBrad | Idle Banter | 36 | 10-10-08 07:25 PM |
FAO Fizzy Fish!! | rigor | Soho Massive | 2 | 05-09-07 10:55 AM |
Anstruther Fish Bar | The Basket | SV Ecosse | 10 | 25-06-07 06:06 PM |
Anyone keep tropical fish? | Mark_h | Guildford Massive | 31 | 18-04-07 12:36 PM |
