Old 07-07-09, 08:28 PM   #21
merlin427
Default Re: GSXR front end - Clipons
Originally Posted by charlie13 View Post
yep i'm doing things the hard way, but do any of the front end swaps you seen or read about before combine std sv650 wheels or sv dymags with gixxer forks? i'm not parting with my lightweights for anything now. zx discs were chosen as they are matching 320mm OD with gixxer6 discs but have 10mm offset so are as near to sv offset as I can get. still to put it together and see how it all lines up. soon, but don't want to upset mrs.charlie too much by spending all my time tinkering in the run up to getting hitched
I guess you're in good company Charlie, if we liked things the easy way none of us would entertain this. I don't know about others but I rekon I must be at least a little bit mad! Good luck with the conversion. I guess if a front wheel from an can SV can be made to fit this would cut down the expense and keep the 2 wheels matching.
Old 07-07-09, 09:03 PM   #22
The usual trick is to use SRAD GSXR wheels if possible- identical to the SV one cosmetically, a wee bit lighter, and most of all cheaper! But it's harder to do that with the pointies.
Old 07-07-09, 09:19 PM   #23
I've got a GSXR front end to bolt on, which will use a standard SV front wheel & speedo drive. The bloke I bought it off (or won it off on Ebay) offerd to get a spindle & spacers made up to fit the Gixer forks. He'd done the same for his wifes SV, so he knew what needed doing.
At th mo, I haven't had time to fit it all together to see if it works. I'll post some pics once I get going. If need be, I might be able to get some drawings made up.
This is for a Curvy & I'm fitting a 1991 GSXR 750 USD forks. The benefit is that the steering head bearing are the same as the SV's, so no need for a TWF special (i hope )
Old 07-07-09, 09:23 PM   #24
merlin427
Is the SRAD wheel compatible with the later forks? I'm looking to use K4/5 600/750 (or K3/4 1000) on a pointy (Is this fork setup compatible with teh curvy does anyone know?)
Old 07-07-09, 10:02 PM   #25
not quite... its a couple of mm out... me and YC have had a discussion about this.. but no one has tried it. spindle sizes etc.etc seem to coincide, but its getting the discs to fit inside the callipers. i will however be doing it over the winter as the srad front wheel matches the sv rear wheel better.
Old 07-07-09, 10:11 PM   #26
With the right yokes and spindle, that'd work perfectly in a curvy... But not in the pointy I think, to get good functionality you need to run later yokes which are designed for the more modern, narrower wheels, so the disc track ends up too far out. And with radial calipers, that's a pain. It doesn't matter if they're a wee bit off centre but you've only got mm to play with.
(PS, use the 600/750 forks, the thous then all used Kayabas which are perfectly nice, but not as good)
Old 07-07-09, 11:24 PM   #27
chakraist
If you can find them, the Ducati 900SS clipons fit perfectly, no fouling. It's what's on mine, and whilst I can't drop them as much as I would like, I would have this problem with any clipons due to tank fouling etc.
Old 08-07-09, 12:32 AM   #28
only if they are USD forks as they are 50mm, i was also contemplating using the duke ss clipons but decided on gilles as i'm a tart.
also the duke ss clipons are so comfy and angled just right.
Old 08-07-09, 05:48 AM   #29
charlie13
if you've got the gsxr750 steering stem somewhere handy just check that the top section of the stem where the bearing will be is 25mm. standard sv650 upper steering head bearing is 25 ID x 47 OD x 15thick. technical drawings aren't a problem for me, it's part of my job! more than happy to do some techy doodles for bikey bits for folk on the org if ever needed
Old 08-07-09, 10:13 AM   #30
The slingshot GSXRs all use the same head bearing kit as an SV
Sv 650 2nd genaration front wheel,fender,clipons TOLAROS For Sale - SV's and SV related items 9 20-01-16 06:10 PM
GSXR 600 SRAD Front Forks, Yokes & Clipons for Curvy SV650 Conversion Ter For Sale - SV's and SV related items 3 19-07-07 07:38 AM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
