Old 23-08-09, 08:35 PM   #21
Mej
Default Re: Removing FI Kit from Pointy????
Old 23-08-09, 08:38 PM   #22
Wideboy
Evel Knievel
Wideboy's Avatar
the carbs are help onto the intake ducts bye a screw clip....... the intake ducts are located directly beneath the carb bodys, you need to lossent he clips and pull the carbs upwards.
you may need to remove the fairing sidepanels to get to be able to see under the carbs, i had to for the curvy
05 DRZ400E
RIP hovis
Old 23-08-09, 08:47 PM   #23
Mej
im in under the carbs!!! now what
Old 23-08-09, 08:48 PM   #24
Wideboy
Evel Knievel
Wideboy's Avatar
have you got the carbs off the intake ducts?
05 DRZ400E
RIP hovis
Old 23-08-09, 08:51 PM   #25
Mej
Old 23-08-09, 08:52 PM   #26
Wideboy
Evel Knievel
Wideboy's Avatar
then look down the intact ducts and you should see the washers, they should be on the top
05 DRZ400E
RIP hovis
Old 23-08-09, 08:53 PM   #27
Mej
i cant see anything, ill post pics
Old 23-08-09, 08:55 PM   #28
Wideboy
Evel Knievel
Wideboy's Avatar
ok
05 DRZ400E
RIP hovis
Old 23-08-09, 08:59 PM   #29
Mej
Old 23-08-09, 09:00 PM   #30
metalmonkey
Are you sure your bike is not restricted through the ecu? That is normal thing for injected SV...
Removing pointy tank? ibshort SV Talk, Tuning & Tweaking 7 25-06-09 11:04 PM
Removing Front Indicators From a Pointy COLZO SV Talk, Tuning & Tweaking 4 24-01-09 12:33 AM
Removing the ecu-restrictor from a pointy shonadoll SV Talk, Tuning & Tweaking 4 15-10-08 02:58 PM
Removing stock exhaust, K3 Pointy MiniMac SV Talk, Tuning & Tweaking 7 21-03-08 06:21 PM
Removing Pointy Lowers Wadda SV Talk, Tuning & Tweaking 0 13-03-08 12:35 PM
