#21 |
cheers druid i ll have that off ya mate pm me interesting things on how to give you money
#22 |
Actually yes I do although I don't know the state of it (it's prettier but I've never tried it).
Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#23 | |
If I'm honest I preferred it to the Ohlins but I suspect that's more I haven't got that properly setup rather than it's better. Druid
#24 |
Any of those shocks still going spare?
Update, I have a frame, a motor and a TIG welder... so about the same as months ago, but now my welding is a little prettier ![]()
#25 |
I can Tig Weld Stainless if you provide the Welding equipment
![]() Just seen Yorkies post above , I can also make brackets and machine stuff , heck give me acces to a lathe and a milling machine and I can make you allsorts ![]() Last edited by xXBADGERXx; 31-10-09 at 07:07 PM. |
#26 |
Learning the TIG myself, getting slowly better
#27 |
I can do very tidy welds on large Diameter pipework like exhaust diameter , especially if it`s an Argon Gas and Tungsten Tip setup .
#28 |
I can MIG weld you pretty much anything you want. I have access to a BIG shed which houses my £1000 mig welder
#29 |
Can you MIG aluminium?
#30 |
Me personally ? or is it possible do you mean . I have had a go at it and there is a fine line between blowing holes in the Aluminium or getting no penetration on the weld itself . You`ll need a very nicely set up MIG welder in fairly good condition . Don`t forget that a lot of bike frames and things like that will use a special type of Aluminium that will have different characteristics after extreme heat is applied to them .
eye ball yellow "n" and a blue "s" curvey!!! | cymroboi | The Border Patrol | 5 | 19-06-09 08:09 PM |
Using "Pointy" Tensioners in a "Curvy"? | dtr125 | SV Talk, Tuning & Tweaking | 25 | 05-02-09 05:42 PM |
teh "what you doing this weekend thread"...sponsored by Chesley "Sully" Sullenberger the Third | keithd | Idle Banter | 30 | 18-01-09 11:47 AM |
Rideout "Sections" or "Groups" | independentphoto | Bikes - Talk & Issues | 19 | 04-09-07 01:08 PM |
Front "Braker" or "Rear "Braker" &q | BURNER | Bikes - Talk & Issues | 9 | 27-02-05 01:04 AM |
