Old 16-10-09, 10:04 PM   #21
7755matt
Default Re: ABBA Stand fittings
Originally Posted by rigor View Post
I would suggest that the mounts weren't sitting on the swingarm pivot bolt thingy correctly. If it's done up tight and they are fully engaged it can't slip off.
When i had it all set up like the video they seemed to be well in and everything was tight. Or at least as well in and tight as you could get with the bike on the angle the side stand puts it on. Is it just my curvy that seems to lean a LONG way over on the stand. The fittings seemed to apply a lot easier, do up tighter etc when the bike was upright
Old 16-10-09, 10:37 PM   #22
petevtwin650
I can't see what difference it being on the side stand makes. You put the appropriate fittings in, pull the stand together tight and do up the knurled bolt that locks the frame together, then wind the handle that pushes and retains the adaptors home. Once that is wound in and the frame bolt done up, I still cannot see how the bike falls off it.
Used mine dozens of times, often leaving it on for days at a time. No problem whatsoever.
Old 17-10-09, 05:12 PM   #23
phi-dan
phi-dan's Avatar
How different are the pointy fittings from the curvy? If they're similar you can pop up and borrow mine.
If not - oh well
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 17-10-09, 05:15 PM   #24
Alpinestarhero
Thats interesting to note, I had my curvy up the stand for the first time the other day and it fell off mainly due to how badly they fit. Its put a big scratch on teh frame.
really? I have never had any bad events happen with my abba, I use the standard ABBA-supplied bobbin things. Always make sure its nice and tightly done up.
I also find it easy to get on and get the bike up on it (i do it so the bike rolls forward)
Old 17-10-09, 05:28 PM   #25
If not - oh well
Sorry they're different between curvy's and pointy's
The number next to the year and model is the ABBA adaptor kit you need
SUZUKI
RG250/RGV250 24
RGV250 97-ON 14
GSXR400 24
RG500 STD
GSX600F STD
GSXR600 97-03 14
GSXR 600 04-O5 40
GSXR 600 2006-ON 50
RF600/900 23
GSR600 50
SV650 UP TO "02" 25
SV650 03-ON 42
Old 17-10-09, 07:34 PM   #26
phi-dan
phi-dan's Avatar
D'Oh!
Now: Blue FZ6 Fazer
Old 17-10-09, 10:22 PM   #27
I've had mine and a fair few others on the abba stand on my fairly uneven garage floor while I've used sledgehammers, cracking bars with scaff poles on them for more leverage, allsorts.
I've even turned a curvy without its swingarm upside down on one.
Never dropped one, what are you lot doing wrong?
Abba stand Lucas Stuff Wanted 1 01-09-09 01:17 PM
Abba Stand & SK8? simonDyna SV Talk, Tuning & Tweaking 16 05-08-09 04:27 PM
Abba Stand Fittings - For Curvy Demonz Stuff Wanted 5 29-07-09 12:59 PM
Paddock stand/abba stand or? Ruthja2801 Bikes - Talk & Issues 18 26-02-09 12:20 PM
center stand / abba stand? New Leaf Bikes - Talk & Issues 3 29-01-08 01:58 PM
