#21 | |
Then again, it's not going to warp or burn if full of water.
#22 | |
Oh and i've just realised you've got a combi, you'd have to run seperate HW supplys to the sinks/basins to get it to work so knock that idea on the head. It's do able though and a good use of the heat, but alot of messing about. D'oh
RIP Hovis - Unlucky Boyo
#23 | |
If not, BOOM ! Re price of coal: Has Missyc jibbed at going down the pit again?
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#24 | |
Alot of the newer solid fuel boilers have thermostats controling the airflow to the fire therefore controling the fire bed preventing it getting too hot and burning too much fuel. Thats the only problem I can see with yours is its control. If you don't put enough rads on taking heat away from the boiler the system could just end up like one big kettle no good to anyone and a potential danger.
#25 |
I would fit a blow-off valve as matter of course anyway if we do use it. The slight problem being I don't know this boiler has been pressure tested so don't know what to set a blowoff valve at!
Pressure buildup on the open system idea wouldn't be too much of an issue as any steam could bubble out of the expansion tank.
#26 | |
just don't use a plastic tank, lol. |
#27 |
You don't see many of those in the scrapyard
#28 | |
Open has been fine for a long time for this sort of thing ![]() If you going to refit the tank just make sure that you have the outlet at the top and the inlet at the bottom. That way the hot water will convect away to be replaced by the cold. You need a rad big enough to be a heat sink but if the tanks is 2kw then choosing a rad size is not hard from the manufacturers specs. if the rad is below the tank you need a pump to drag the hot down into it. I bet you will have spent not far off the cost of a new stove by the time you're finished though.................. |
#29 |
There was never the intention to pressurise it
![]() There's no way to fit the boiler so convection will circulate water, it fits horizontally over the top of the fire so inlet and outflow are level. If we were to put flexible tubing under the wooden floor, how much heat does that type of tubing dissipate per length?
#30 | ||
Hepworth, speedfit (john guest). |
.Org Plumbers? | Dave20046 | Idle Banter | 213 | 09-04-12 08:51 PM |
Any Plumbers in the house??? | DF! | Idle Banter | 3 | 02-12-08 09:58 PM |
Underfloor Heating | Gazza77 | Idle Banter | 9 | 10-06-08 08:17 AM |
Any plumbers on here? | ukgooner | Idle Banter | 15 | 27-04-08 11:50 AM |
Plumbers help with my new bathroom | furrybean | Idle Banter | 27 | 06-02-07 09:23 PM |
