Old 19-11-09, 09:28 PM   #21
the_elements_600
Default Re: SV running rough, cutting out
Originally Posted by empty View Post
Black and oily isn't a great combo, you'd normally expect them to be a sort of dark brown. Does the bike burn any oil (visible smoke) or do you have to fill it up with oil often?
Idle speed should be approx 1300rpm. I'd also check the clamps holding the throttle bodies on are tight, the vacuum point rubbers are intact and, if you have gauges (or can borrow some) the throttle body balance.
MT
Haven't checked the oil for a bit actually, will make a note to do that tomorrow. There's a tiny bit of visible smoke (nothing major at all) upon start up, but once the bike's warmed up it goes away.
Just adjusted the idle from 1000 to about 13-1400. Hopefully that will have sorted the problem!
rough running ? mikey devon SV Talk, Tuning & Tweaking 11 21-03-09 12:07 AM
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
Rough running after several months off :( Gasman SV Talk, Tuning & Tweaking 3 23-12-05 07:17 AM
