Old 10-12-09, 01:56 PM   #21
Default Re: Soldering for Dummies
don't think there are any true 'wrought iron' blacksmiths left. its all mild steel these days.
ok so i'll rephrase the 'blacksmith' (even though we also done anvil work) part and say 'fabricator/erector'.
Old 10-12-09, 02:31 PM   #22
timwilky
timwilky's Avatar
Agree wrought is not commercially available these days. It was the malleability that made it the ideal material for true forge work. Sadly mild steel does not have the same qualities
Not Grumpy, opinionated.
Old 10-12-09, 02:47 PM   #23
Alpinestarhero
What makes a "mild" steel? How are other steels classified?
Old 10-12-09, 02:50 PM   #24
timwilky
timwilky's Avatar
Steels are really down to the carbon content. You will normally hear of mild being described as low carbon steel. But the metallurgy is a science in its own right.
Just google iron carbon equilibrium diagrams and start to get baffled as you start looking at martensite, perlilite. Wonder about austentetic phases etc.
Old 10-12-09, 02:51 PM   #25
amongst other things carbon and impurity content.
bit long winded but easy to understand:
http://www.istc.illinois.edu/info/li...s/chapter2.htm
Old 10-12-09, 03:08 PM   #26
DanAbnormal
In the US they like to SODDER!!
Weirdos.
Old 10-12-09, 03:17 PM   #27
Alpinestarhero
Weirdos.
they like to do that in brighton too
huhwhateh?
Old 10-12-09, 04:24 PM   #28
Just get some bits of wire and see how it works, it's not particularly hard.
Just make sure your metal is clean and slide the heatshrink onto the wire before soldering the wires.
(and don't leave the heatshrink too close to the joint, or try to slide it on until the joint has cooled.)
I find a simple butane lighter the easiest way to heatshrink tubing, I find the iron is too harsh.
Old 10-12-09, 04:31 PM   #29
ophic
ophic's Avatar
Double check this. I constantly forget - along with any connectors or covers that need to go there too. Soldering, swearing, desoldering and soldering again makes a mess. And sods law says that the first solder job is always incredibly neat.
Silver SV650SK3, Fuel exhaust
Old 10-12-09, 04:34 PM   #30
just what me was gonna say .. few times when conecting my autocomm etc I have forgot to slide the heatshrink over first and keep it wel away from the joint.. so tried to cut it down it length after and wrap it on and then shrink it and it doesnt work.
so make sure you slide the heat shrink on and down the wire first ASH .. and yea butane lighter way easiest way to shrink it on.... self almalgamating tape is good too,,. me use that first then heat shrink
Racing for dummies captainsmelly Bikes - Talk & Issues 9 20-05-09 05:06 PM
iPod help for dummies (thats me)! please. SV-net Idle Banter 3 20-12-08 11:31 PM
'Uploading a photo' for Dummies LindaS Idle Banter 3 16-04-08 05:52 PM
winter storage for dummies drumroll SV Talk, Tuning & Tweaking 32 07-09-07 11:10 PM
Soldering electrics - tips and tools? muzikill SV Talk, Tuning & Tweaking 3 14-06-07 02:52 PM
