Old 22-01-10, 07:06 PM   #21
Default Re: Org'er in need of a mechanical Guru!!
Originally Posted by sunshine View Post
offense taken special one
doing as i say wont damage the engine anymore than it already could be, the rear plug is difficult? you mean the front if difficult?
to get the the read lift the tank, pull the lead out and use the plug spanner in your tool kit to remove the rear one, the front one is abit harder, unbolt the radiator at the bottom only push it away from the front plug gently pull the lead out and again using the plug spanner from the suzuki tool kit remove it and in gear give it a push. if it rolls away the engine is "salvageable" easily provided the engine is turning over.
Whoaaaw cowboy, i wasnt meaning anyone in particular.
The statement about a professional also excluded me from that.
My gut feeling about this lads motor is fubar but im no 'professional', hence the reason why i said get one.
Old 22-01-10, 08:22 PM   #22
Noble Ox
Owww. I googled FUBAR! lol
Il keep my eyes peeled for decent 2nd hand engines then
Old 23-01-10, 08:51 PM   #23
sunshine
i thought someone who has known me long enough would of noticed the sarcasm in my text, remind me to insert more smilies next time
have you checked the things i have suggested? what were the results?
Old 23-01-10, 10:29 PM   #24
Dave20046
Dave20046's Avatar
I would, in the mean time see if your current one is salvageable (p.s major de ja vu on this thread ) but if you don't have the mechanical know how to strip the engine and fix it yourself I think your best bet is getting a replacement engine at a good price and paying/convincing someone to swap it for you, as a straight engine swap would be less messing about (which means less £ if you're paying) than taking out an shagged one, stripping it, waiting for parts & bumming about etc. (if it can even be salvaged) and then putting it back in and hoping it works.
I hope you can atleast make a good brew
Old 24-01-10, 01:08 AM   #25
barwel1992
im tempted to go and have a look for him dave, just to give a helping hand to drop the plugs and stuff, bit skint on cash atm but i may be able to tie in with going to see me nan lol (she lives in Solihull and pay's my fuel lol)
Old 24-01-10, 09:36 AM   #26
At least if you buy a 2nd hand engine, you can flog off some of the salvagable parts to recoup some of your outlay for a replacement engine.
Pointy cams are sought after by curvy owners and racers as an instant power gain, so they go for reasonable money
Old 24-01-10, 10:37 AM   #27
beabert
I can drop round my compression guage so you want? you can check the compression, im in redditch. I have the confidence to rip my own things apart but not others lol, but im happy to stay and maybe help.
John carew carewwwwwwwww, he's bigger than me and yooooooooooou.
Old 24-01-10, 10:54 AM   #28
Dave20046
Dave20046's Avatar
I'd avoid trying to start it though as it's most likely seized guys.
Old 24-01-10, 11:11 AM   #29
beabert
/Attempt a manual turnover first ofcourse
Old 24-01-10, 04:12 PM   #30
sunshine
without check the things i have said im not leaving my house to look it over, and all engines can be rebuilt unless the engine casing is smashed/spilt. its just the cost of parts/professional machining. so when the op says he cant get the plugs out or has checked what i have said im not considering get out to look at it.
You dont really need a compression test as the engine isnt moving in gear with the plugs in normally implies compression.
New Org'er!!! coombest Idle Banter 18 13-01-10 09:49 AM
mechanical help? 2hys SELKENT 5 15-11-09 11:05 AM
Mechanical Help Please! Noble Ox SV Talk, Tuning & Tweaking 59 08-11-09 03:15 PM
Did I spot a .Org'er tj2 Idle Banter 0 24-08-09 04:26 PM
which org'er do you fancy? Wideboy Idle Banter 204 25-10-08 09:38 AM
