Old 03-02-10, 10:45 PM   #21
Default Re: Regulator chat thread.
Set it to AC-Voltage and see what it is putting out, you should have some decent voltage there. 70V-AC at 5krpm or more.
Old 03-02-10, 10:58 PM   #22
beabert
From my understanding, which aint much, you completely disconnect the rectifier from the bike. The diode function outputs voltage to see how much it takes to overcome diode potential.
Mines are all out of spec.
No tested the alternators output on mine yet, as above it should be 70
Old 03-02-10, 11:00 PM   #23
I don't trust diode test of Reg-Rec. I've had a couple check out tip-top and be completely knackered.
See what's going into it and what's coming out of it, if those aren't the problem then you know it is the RR.
Old 03-02-10, 11:05 PM   #24
beabert
I see where your coming from, especially because of how hot they get.
Mine checks out knackered to start with and outputting to high of a charge, so im confident its gone tits up, not to mentioned a knackered battery.
Old 03-02-10, 11:06 PM   #25
Almost certainly
There would have to be a very wierd problem to get an over-volt situation with something other than the reg-rec at fault.
Old 03-02-10, 11:09 PM   #26
beabert
I have had no end of weird problems in my 25 yeas on this planet lol. I dont fo a minute expect everything to go as planned, some git has probably added extra windings lol.
Old 04-02-10, 01:30 AM   #27
5hort5
Actually with uniformly slightly under-volting like that I would check all the wiring voltage drops before buying a new reg rec
Hi Chris,
when you say "check all the wiring voltage drops" what does that mean to someone who has never touched wiring before?
Thanks
5hort5 is offline   Reply With Quote
Old 04-02-10, 01:48 AM   #28
beabert
I think what he is getting at is if the rectifier is recieving a lower voltage than normal, then the voltage levels across the board will be all uniformly lower in all tests (light on etc), and if the voltage levels are all over the place then its more likely to be the rectifier.
Check the voltages entering the rectifier first ill post a picture of the page from the manual, one sec....
Old 04-02-10, 02:04 AM   #29
beabert
Another one here 5hort5
http://cgi.ebay.co.uk/honda-cbr-1000...item53df442953
Cant get the fancy connectors for these, but spade terminals work fine.
Old 04-02-10, 02:15 AM   #30
5hort5
Tomorrow I will mainly be in the garage - again
Photo Comp - Chat Thread 5hort5 Photos 1254 15-06-20 04:13 PM
welsh TT weekend away (take 2) Banter / Chat thread hovis South & West Surfers 452 13-10-09 04:00 PM
North Wales Rideout #4 thread - Please use this for chat Luckypants The Border Patrol 287 26-11-08 09:44 AM
SV Ecosse Glencoe Massacre chat thread Lissa Rideouts & Meetings 66 23-07-08 01:30 PM
Booking chat thread. rictus01 2007 Annual Rideout 110 27-06-07 02:15 PM
