Old 20-03-10, 08:29 PM   #21
tigersaw
tigersaw's Avatar
Default Re: Tommorrow I will be mostly....
Nope, I just assumed I was buying those small rolls like you get in B+Q and walk out with under your arm, so I ordered a dozen.
What turned up was a hiab truck with a pallet load, each one the size of a post box, and thats before they unpinged.
Old 20-03-10, 08:33 PM   #22
Make sure there's room for air to ventilate from the sofit boards otherwise you'll have condesation problems and it won't do the timber any good
Old 20-03-10, 08:34 PM   #23
lol, mine came free years ago from a goverment scheme. Man looked at loft and said, well its getting borderline, we'll fit it anyway. Its like an itchy bouncy castle up there!
Old 20-03-10, 08:36 PM   #24
tigersaw
tigersaw's Avatar
Thats round the edges? Yes, I didn't push it right to the edge, you can still see down the gap - assume thats right
Old 20-03-10, 08:38 PM   #25
Yep, depending on where the vents are, so long as they're not covered over, then the loft space will get enough ventilation to prevent condensation
Old 20-03-10, 08:59 PM   #26
tigersaw
tigersaw's Avatar
You can still see the white thingummy all around the outside edge, which I guess is the back side of the plastic facia, and down the gap, though I dont know how it is ventilated, guess there are vents in it, or do they just build it sloppy?
Old 20-03-10, 09:31 PM   #27
Looks ok, you should be able to see the vents from the outside, depending on what type they are.
But yours looks similar to mine and I don't have any obvious vent holes, although mine gets ventilated ok
Old 20-03-10, 09:34 PM   #28
Not much room for storage then..
Old 20-03-10, 09:37 PM   #29
tigersaw
tigersaw's Avatar
Meh, thats what the garage is for
Old 20-03-10, 09:44 PM   #30
Amanda
Tomorrow I will be mostly .... painting childrens faces under a gazebo in a car park in the rain!!!!
Free Cinema ticket tommorrow (5/4/07) Stu Soho Massive 4 04-04-07 02:24 PM
piccies potentially !!! tommorrow Quiff Wichard Photos 44 08-05-06 03:18 PM
me- posts- tommorrow - The Forum Quiff Wichard Idle Banter 2 26-04-06 11:29 PM
