#21 |
Simulate the injectors? Power resistors?
#22 | |
![]() didn't thinck off that. Good idea, but I thinck it wouldn't cure it totaly. I'm sure I could use more liters out off the tank, but problem would remain with the last couple off liters : to much time between sucking air and fuel again. the high pressure fuel-pump needs constant flow of fuel. I'm already at my second Busa-pump, because I thinck the first one gave up having turned too much without fuel . I'll see if I can get one quickly and try it out, 'cause I'm already searching ebay to see who has most parts I need to save on shipping costs . |
#23 |
IMO you need a loop and reservoir at intermediate pressure. Rather than complete flow and return cycling by HP pump.
This would reduce duty cycle of your low pressure fuel pump to point where it would not overheat. Section of 25mm pipe maybe 2" long would be fine reservoir IMO, does not need huge volume. You could hide it down side of subframe or something.
#24 |
if you create a loop, and air gets in the loop, it'll never get out. that's why the return has to go to the tank.
#25 |
Create small reservoir like I say, bleed off small proportion of flow from your LP pump from top of this back to tank. Will get rid of air without exceeding capacity of your LP pump.
#26 | |
![]() looked into the manual, and appart from the injectors and TPS, everything else could stay. So if I just take out the injectors from the bodies and keep them on the loom, and if I can transfer the TPS (or maybe, just maybe if I'm very lucky if just works with the TPS from the carbs), it should work. now off to ebay and buy some carb's ![]() edit : forgot about the STVsensor/activator . will have a look first if I can just put the sensor directly on the actuator and leave it also in place. Last edited by janbros; 24-05-10 at 11:56 PM. |
#27 | |
The Sick Man
have you thought of cutting the tank and changing its internal profile or lifting the tank at the front
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#28 | |
#29 |
did some tests :
* STVA needs to be connected, but the electrical motor on it's own is enough, it doesn't need to function. * STP needs to be connected, and in the valve closed postion with the STVA-motor detached from the throttlebodies - if not -> fault * injector's don't need to be attached (at least not with just ignition switch on) For the ignition to work, only the CKP, TPS, GPS and engine coolant are required. So I'm gonna buy carb's , leave everything unnesascary in the loom (and that's a lot ![]() Than I can have some time to test it. But in the end I'll swap everything for the curvy parts, but like this, I can wait for cheap parts, and not have to buy something ridiculously expensive because I'll need it ![]() |
#30 | |
The Sick Man
just get a carbed loom as its fairly cheep, you dont need clocks to check if things are working
After swapping the loom out. | Grinch | SV Talk, Tuning & Tweaking | 44 | 08-12-08 11:34 PM |
carbs Vs fuel injection | hovis | Bikes - Talk & Issues | 14 | 09-11-07 05:43 PM |
Curvy - Is it injection/carbs? | TheStudent | SV Talk, Tuning & Tweaking | 3 | 15-09-07 07:33 PM |
Swapping Radiators | squirrel_hunter | Bikes - Talk & Issues | 9 | 13-05-07 02:38 PM |
Swapping the exhaust | mysteryjimbo | SV Talk, Tuning & Tweaking | 2 | 06-10-04 10:48 PM |
