Old 08-07-10, 10:47 PM   #21
Nicky S
Nicky S's Avatar
Default Re: k2 curvy running problem
Originally Posted by Biker Biggles View Post
So many curvy running issues are down to dodgy choke plungers.You need to get that mullered screw out and check the innards.And the other cylinder.
ill have the choke plungers out 2moz, what you mean the other cylinder
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 08-07-10, 11:00 PM   #22
Biker Biggles
Biker Biggles's Avatar
Theres another one the same on the other carb.That needs maintenance too.
Old 08-07-10, 11:02 PM   #23
Nicky S
Nicky S's Avatar
ohhh yer i know sorrie had a stupied moment
Old 12-07-10, 11:02 PM   #24
Nicky S
Nicky S's Avatar
right i have gone all over the carbs cleaned them and put them back on the bike still have the same problem.
i went for a quick ride to see if it was any better and it feels like im ridding with the front brake on the hole time and it back fires and pops a lot.
i decided to have a look over the engine again and took the front HD lead off and run the bike it still runs funny. so placed it back on and took the back HD lead off. bike runs fine.
so my next step is to check the coil??? the black box that the hd lead gose into iv got a haynes manual so ill do it as it says. then also check the compression
what do you think ?
Old 13-07-10, 08:29 AM   #25
The bike runs fine with no rear HT lead? I doubt it!
Old 13-07-10, 10:04 AM   #26
embee
embee's Avatar
Did you get the choke cables and plungers really free and clean?
Like the others have said, sticky choke cables and/or plungers will cause real running problems on the curvey, and the plungers only have to be cracked off their seats a fraction to cause it. I had this problem on my curvey when it was only a month or 2 old due to white crud at the end of the cable where it meets the plunger (I believe it was flux from cable manufacture).
Are the plunger springs in good condition? They can rust and break eventually.
Oil everything liberally when you reassemble them, especially running some oil into the cables. Make a small funnel out of a plastic bag corner held onto the end of the cable outer with a rubber band and leave it suspended with thin oil in it for a few hours (overnight etc) for the oil to work its way down.
Old 13-07-10, 10:16 AM   #27
If you get some spray grease and a spray nozzle off the WD or something you can pack the cable splitter with grease very easily
Old 13-07-10, 02:30 PM   #28
Nicky S
Nicky S's Avatar
well no it dont but it runs with out any problems .. like poping and back fireing. i didnt ride it jsut started it
done all of that already
done that 2 after i watched your video
Old 13-07-10, 02:35 PM   #29
MrMessy
The rear coils are prone to failing on curvy's.
MrMessy is offline   Reply With Quote
Old 13-07-10, 02:55 PM   #30
Nicky S
Nicky S's Avatar
are they iv never read that... but im hopeing that is what it is, going to test it sometime this week
Fazer running problem. warrenhewitt10 Bikes - Talk & Issues 32 06-05-10 06:04 PM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
sv running problem? any ideas Crunchy SV Talk, Tuning & Tweaking 6 31-07-09 04:27 PM
And you thought running out of oil was a problem... gettin2dizzy Idle Banter 22 11-06-08 08:04 PM
Odd choke/running problem northwind SV Talk, Tuning & Tweaking 13 07-06-05 11:46 AM
