Old 10-07-10, 10:56 PM   #21
Kilted Ginger
Default Re: Hello
glad u gotit sorted.
Old 11-07-10, 11:45 AM   #22
muzikill
muzikill's Avatar
Default Re: Hello
Welcome the the org - had the same problem a few moons back, sidestand switch, had been a bit over zealous with some oil getting rid of the 'creaky' sidestand spring noise/rust and must have got into the switch at the top.
How many failsafe switches does a pointy need!
Old 11-07-10, 01:08 PM   #23
chops9
Default Re: Hello
Hopfully I'll hav it up and running for the Aug 1st meet. It's a bit of overkill with all the switchs alrite.
