Old 06-09-10, 10:30 PM   #21
punyXpress
punyXpress's Avatar
Default Re: computer GEEK required
If DP isn't safe on some bikes, is it a wise move to let him loose on mains electrics ?
Now: Street Triple R
Old 06-09-10, 10:33 PM   #22
jonny.boyd
jonny.boyd's Avatar
Haha, well that will be up to himself and those who live with him! =p
jonny.boyd is offline   Reply With Quote
Old 07-09-10, 02:03 AM   #23
TSM
The Sick Man
TSM's Avatar
Originally Posted by davepreston View Post
right i have one phone socket,its down stairs
i want internet access upstairs, i have wifi but due to " interferance" its quite a sh1te connection
so geeky people ( im looking at you SK TSM SAXO)
what is the cheapest way to achieve this, is it possible to boost wifi in my room without running wiring, also is it possible to have a second phone upstairs too again without a phone socket, bt are asking stupid money to fit one
over to you sad people
try and move box to better location first, a simple telephone extension cable may surfice, look out for solid walls between the box and the target location
wireless repeaters are a bit poo as most of them work with a single radio and so 54mbps (theoretical speed) is halfed to 28mpbs instantly, take off losses and real world speed fluctuations, add in latancy and its poo
also if you can get a wi-fi sniffer (netstumbler) installed on your computer to monitor the airwaves and work out which channel number has the least interfearance and also other boxes sharing the same channel, change config on wireless box to match new found channel
the last thing and the best would be to install a second wireless box but make it wired to the first, set both up with the same password and ssid but on diffrent channels, that means you can roam between them without any real problems, most complicated but best
Old 07-09-10, 07:14 AM   #24
maxinc
Try a "n" wifi router instead. They are usually way better than "g" models inside the house.
Old 07-09-10, 08:42 AM   #25
phi-dan
phi-dan's Avatar
If you're safe to be let loose with scissors and glue, then you could try this: http://www.instructables.com/id/DIY-...ption-Booster/
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Computer Help Required fenjer SV Ecosse 30 02-12-09 07:51 AM
geek help Bibio Idle Banter 9 16-05-09 01:22 AM
Another computer geek thread andyb Idle Banter 13 01-05-08 01:54 PM
Computer buff help required... valleyboy Idle Banter 23 24-12-06 10:17 PM
Hi all computer help required GSXR Carlos Idle Banter 16 16-01-06 11:00 AM
