Old 08-12-10, 09:58 PM   #21
barwel1992
Default Re: Hayabusa and sv piston size, cylinder and clearnace information
ahh, you should use new rings though with the new hone so they ware and mate together
Old 08-12-10, 10:16 PM   #22
barwel1992
ohh and just so every one knows
the SFV gladius now has alloy/plated cylinders with the same size pistons as the busa not sure what the piston to bore clearance is but i bet its about 0.020-0.030mm
Old 11-12-10, 05:55 PM   #23
svsam
svsam's Avatar
PS will have 2 busa pistons and pins for sale soon as well if any one else wants a go lol
may have to take you up on that for future work. how much you thinking?
svsam is offline   Reply With Quote
Old 11-12-10, 05:58 PM   #24
barwel1992
about £60 + P&P
for 2 pistons 2 pins new the RRP is £119 each pistons and £13.97 each pin so rrp for both pistons and pins is £265.94
the pistons have 7k miles on them but will give you detailed pics when i get them (on the way from US of A)
Old 11-12-10, 09:30 PM   #25
suzukigt380paul
if you hone the bore 0.030mm does this not give you a bigger end gap on the rings thus giveing you more blowbye on the piston,and does useing a lighter piston put the crank out of balance,"just a thought"
Old 12-12-10, 12:06 AM   #26
barwel1992
Originally Posted by suzukigt380paul View Post
if you hone the bore 0.030mm does this not give you a bigger end gap on the rings yes but not enough to worry about
thus giveing you more blowbye on the piston as above
and does useing a lighter piston put the crank out of balance once again yes but not enough to warrant the £200+ to have the crank balanced if i changed the rods then yes i would need balancing
SV front master cylinder - OK with 4 piston calipers? barwel1992 SV Talk, Tuning & Tweaking 12 02-07-10 05:45 PM
It's a Hayabusa or is it? TheRamJam Bikes - Talk & Issues 20 25-04-10 08:30 PM
curvy master cylinder banjo bolt thread size? stuballs SV Talk, Tuning & Tweaking 1 01-03-09 05:18 PM
Anyone know the '99 rear master cylinder brake thread size? Ter SV Talk, Tuning & Tweaking 2 19-10-06 05:13 PM
What size is the banjo for the rear master cylinder? northwind SV Talk, Tuning & Tweaking 11 27-04-06 11:08 PM
