Old 08-01-11, 05:26 AM   #21
Default Re: What is stock fork oil for GSXR 750 SRAD forks?
i'm far from being an expert on this subject but here is my 2ps worth.
being a fatty or a skinny has not much to do with it. cartridge forks are a completely different beats to conventional. to thick an oil in cartridge forks will slow the reaction times down which is bad as this will result in loss of traction. the oil ways are a lot smaller than conventional so to heavy an oil will not allow oil to flow freely and let the shims do their job properly. conventional forks have larger oil ways and no adjustment so to fine tune conventional you use thicker oils or a blend till you get the correct viscosity that gives you a good dampening effect. both are dependent on having the correct spring for the rider in the first place. dampening is to control the spring and nothing more, to hard (slow reaction time) and you loose traction to soft (fast reaction time) and the same.
but its late and i like to talk shizzz..
Old 08-01-11, 12:37 PM   #22
TamSV
TamSV's Avatar
Makes sense to me Bib.
I've pretty much decided that, at a tenner a bottle plus my own free labour, I can afford to do some experimenting.
Srad wheel on gsxr 1000 k2 forks? widget Bikes - Talk & Issues 3 19-10-10 11:35 AM
GSXR Srad USD forks maviczap SV Talk, Tuning & Tweaking 4 02-11-09 12:12 AM
k3 gsxr forks onwards fit srad yokes? scottjames SV Talk, Tuning & Tweaking 6 22-08-09 07:08 PM
GSXR 600 SRAD Front Forks, Yokes & Clipons for Curvy SV650 Conversion Ter For Sale - SV's and SV related items 3 19-07-07 07:38 AM
SV GSXR Fork Swap - Keep Stock GSXR Damper? Mesomorphman SV Talk, Tuning & Tweaking 5 08-09-06 07:40 PM
