Old 19-03-11, 05:27 PM   #21
Default Re: Curvy shorter front springs?
Don't bother with dog bones until you sort the shock. Some kawa ones are OK, SRAD is good too if you're light but most are knocking on a bit.
You can't fit a longer rear spring that's not how it works.
Ideally you would get penske shock for rear, ohlins for curvy isn't good.
Old 19-03-11, 05:45 PM   #22
kerby
adding preload to the shock raises the back
Old 19-03-11, 05:57 PM   #23
toxic
and prevents the shock from working if too much is added.
Old 19-03-11, 05:58 PM   #24
Most you are going to get is 337mm all up length of shock. At this point it is totally topped out inside, piston bump washer is against rubber. It cannot go longer.
337 is not enough. Plus it will handle worse than crap with zero sag
Old 19-03-11, 08:44 PM   #25
daveyrach
I have an SRAD shock very comfy
Front Springs - YET again. DANINPLYMOUTH SV Talk, Tuning & Tweaking 82 23-06-09 02:23 PM
curvy aftermarket front springs (hagon, Ohlins, etc) stuballs Stuff Wanted 9 30-12-08 12:37 AM
Standard front fork springs for a curvy Paul M For Sale - SV's and SV related items 4 02-10-07 10:18 PM
Shorter dogbones to raise curvy rear end andyb SV Talk, Tuning & Tweaking 12 08-12-06 02:10 PM
Will SK1 front fork springs fit a curvy? streetos SV Talk, Tuning & Tweaking 3 17-06-05 02:48 PM
