#21 |
Just fitted mine bit encountered a minor issue. Both levers went on fine but now fitted, the sidestand cut out can't be bypassed unless the clutch lever is on the 3rd stage of adjustment or above. I think it's due to the slightly different shape of them and that my heated grips stick out a tiny bit more than standard. Anyone else had any issues with their curvys?
#22 |
My clutch cut out is pretty much on the limit at '3' with my standard pointy bars. But I found the brake lever could touch the bars at anything less than 3 anyway. If you want to use 1 or 2 then you will have to put a spacer of some kind in the lever slot so it moves the switch with less travel. Small fillet of aluminium rod perhaps?
#23 | |
#24 |
Got mine today, 6 days to deliver.
![]() Quality good, anodising looks good on black stubby levers with black adjusters, very pleased. Can recommend motomarts on Ebay. Had to pay £27 tho', wern't doing any at £22 when looking. Only downside is the clutch cover rubber thingy doesn't fit very well now, i am going to see if i can get a spare before I trim the one on my bike. No problems with the clutch switch on my pointy.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground" The Stoppy King
![]() Last edited by SIII; 20-04-11 at 05:29 PM. |
Adj Clutch Brake levers? | edmc | SV Talk, Tuning & Tweaking | 2 | 24-01-11 11:14 PM |
Curvy Carbs, clutch levers and brake levers | 21QUEST | For Sale - SV's and SV related items | 2 | 03-03-10 11:04 AM |
clutch and brake levers in red | Tristec | Stuff Wanted | 8 | 11-07-09 08:57 PM |
2 finger clutch and brake levers | bronze svrider | Stuff Wanted | 2 | 24-07-08 11:49 AM |
Brake/Clutch Levers | Tris | SV Talk, Tuning & Tweaking | 1 | 18-06-07 12:58 PM |
