Old 29-04-11, 02:25 PM   #21
Default Re: Advice on pinch bolt studs please
I would probably wouldn't use stainless simply due to the possible problems of electrolytic corrosion.
Have you ever seen any?
Old 29-04-11, 06:58 PM   #22
Lozzo
I saw plenty of stainless into alloy corrosion on the ZX12R we've just spent a couple of days sorting out. The muppet who owned it replaced a load of fasteners on the bike with un-coppaslipped stainless and then sat it outside for three years. Virtually every fastener needed drilling out.
Old 29-04-11, 09:12 PM   #23
cb1000rsteve
I had a similar experience with my zx7r. I managed to strip the threads off one side of stud holes. I just bought 15mm longer studs and fitted nyloc nuts to the end. Saved having to heli coil or get my mate stiggy to re do the fork bottoms at work
Old 30-04-11, 09:51 AM   #24
Dicky Ticker
Electrolysis is common on many mismatched metals that is why the use zinc anodes in the marine industry to combat it. Not just bolts or other fittings,even rivets can cause it when not in compatible metals.
You would appreciate the damage it can do if you saw the corrosion rate on a boats anode.
Admittedly it is less on a land based vehicle but anything near water carries it,be it surface or internal water on an engine or subsidiaries
Old 30-04-11, 06:27 PM   #25
Yes.
Old 02-05-11, 10:22 PM   #26
Oh yes I've seen it myself on stainless bolts in aluminium holes, but it never seems to be a problem when a drop of copperslip or loctite is involved.
curvy fork pinch bolt(s) eddyb SV Talk, Tuning & Tweaking 1 21-05-10 10:23 PM
Front axle/fork pinch bolt. SV-net SV Talk, Tuning & Tweaking 0 28-06-09 09:38 PM
top yoke pinch bolt torque K4? lee67 SV Talk, Tuning & Tweaking 4 28-06-09 09:20 AM
Yoke pinch bolt torque? Ruthja2801 SV Talk, Tuning & Tweaking 11 08-03-09 10:03 PM
GSXR front end - caliper pinch bolt size? Khewett SV Talk, Tuning & Tweaking 6 10-05-06 06:00 PM
