Old 11-10-11, 10:56 PM   #21
Default Re: chain/ rear wheel noise?
the only way that you can get a rear sprocket to have that kind of lip on the bottom of the teeth it over tightening of the chain. you must be tightening it like a bow string. when the book says 30mm of slack that means 'slack' not forcing the chain to make 30mm, you apply enough pressure to move the chain and that is all, use a straight finger like you are pointing at the tyre then push up on the chain. if it hurts your finger moving it the 30mm then your doing it wrong. an o-ring chain will flex if you force it. the sound of the rear sprocket carrier is the noise you are hearing its just that it's been amplified when its connected and tightened to the swing arm. those bushes look ok, have you checked the carrier bearings for slack?
but as per usual i'm more then likely completely barking at the moon
Old 12-10-11, 07:44 AM   #22
AndyBrad
lip is from manufacture as its zinc plated.
Problems aligning rear wheel after adjusting chain tension aznxk3vi17 SV Talk, Tuning & Tweaking 24 05-06-09 10:51 PM
Rear wheel alignment when adjusting a curvy chain. TheStudent SV Talk, Tuning & Tweaking 7 27-07-08 11:01 AM
Rear wheel chain tension problem? hotrod SV Talk, Tuning & Tweaking 11 21-12-07 09:21 PM
Chain/Rear Wheel questions (long post) thedonal SV Talk, Tuning & Tweaking 27 22-05-07 09:43 PM
taking the rear wheel and chain off, what's involved? Dirty Baz SV Talk, Tuning & Tweaking 17 07-04-05 08:58 AM
