Old 18-03-12, 08:35 PM   #21
NTECUK
NTECUK's Avatar
Default Re: Nitrogen in tyres?
The only thing we use nitrogen is to.locate leaks in the a/c system.
Old 19-03-12, 08:51 PM   #22
flymo
flymo's Avatar
Loads of information around on the net about this.
I found this fairly interesting link http://www.epicentermotorsports.com/...on_Article.pdf
None of the benefits are significant to warrant the use of nitrogen in a road car or bike, especially one that has its tyre pressures checked regularly.
In a race environment, the main benefits are a more uniform change in pressure through a given temperature change. The other reason seems to be that if you have both Nitrogen and compressed air available, Nitrogen would be the better choice for a tyre.
For a road car or bike though, although there may be very small technical benefits, after including the disadvantage of not being able to easily inflate your tyres at home or the local garage, and the fact the many garages charge for the privilidge, it simply isn't worth it.
Use compressed air and regularly check your tyre pressures, simple.
Old 19-03-12, 09:53 PM   #23
SIII
SIII's Avatar
If the tyre is full of air before you start, and you then pressurize it with nitrogen? And air is already 78.084% nitrogen?
What is the % nitrogen increase to? (come on mathematicians work this out!)
Would you not have to fit the tyre in a pure nitrogen environment to get it 100% nitrogen? Or at least purge all of the air out first before filling with the nitrogen?
Snake Oil.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 19-03-12, 09:57 PM   #24
ogden
ogden's Avatar
Yes. Try reading the entire thread, I posted this way back at the start:
http://www.livefrompitlane.com/2011/...g-on-nitrogen/
"For the nitrogen to be effective however, the tyres have to be purged of air (and water vapour) before being refilled with the inert gas, which is why the Marc VDS Racing Team carries a vacuum pump alongside the nitrogen cylinders in the race trailer."
ogden
S1000XR | 990SMT | YZF-R6 #7
ogden is offline   Reply With Quote
Old 19-03-12, 10:02 PM   #25
SIII
SIII's Avatar
Do they do this at Kwikfit? Don't think so!
Rough sums in my head, say nitrogen content would only change from 78% to approx 89% at 30psi or 2 bar. Can't see that making a difference.
The Stoppy King
Old 19-03-12, 10:16 PM   #26
fill yer tyres with nitrous oxide, so when you get a puncture you can at least have a laugh about it.
or how about helium and get squeaky tyres.
i'll get me coat
Old 19-03-12, 10:40 PM   #27
Much better idea!
Old 20-03-12, 05:34 PM   #28
L3nny
L3nny's Avatar
And on another plus side your bike will fly!
2015 GS 1200 Adventure
Old 20-03-12, 09:48 PM   #29
DJFridge
Only if you put Red Bull in the tank too
Old 21-03-12, 01:03 PM   #30
pencil shavings
Actaully - that is quite an interesting point, Helium. Wouldnt that reduce the unsprung weight of the bike? And I guess technically, the overall weight of the bike too?
hmmm
Bike Tyres Leeds - free fitting on Michelin Tyres through Feb & March Paul the 6th Pennine Massive 14 03-03-12 04:59 PM
Liquid Nitrogen phil24_7 Idle Banter 25 10-07-08 08:49 PM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Nitrogen filled tyres kcowgergmm SV Talk, Tuning & Tweaking 9 27-03-07 11:20 AM
Tyres you have... tyres you gettin'? Daz TOTALSV Ireland 6 04-02-05 10:34 PM
