#21 |
Btw if the petrol smells like petrol and the bike has been used in the last year it's probably ok.
Also if you are going to check all of the plugs make sure the leads go back to the same plug hole if they have to come off. |
#22 | |
Ok, I'm alright then. Thanks! |
#23 |
is the fuel pump priming when the ignition is turned on?
What state are the plugs coming out in after a period of non start cranking? wet (fuel) dry? you already have a spark. Assuming the timing hasn't have changed since it last ran: remove each plug, pour a teaspoon or 2 of clean fuel down the plug hole and go for a start, if it fires and chuffes over a few seconds then the issue is injection related ie fuel pressure/injectors etc. whatever it is, it seems common to both cylinders. if it doesnt start then its very odd and its time to start checking spark/valve timing and compression. i know its probably been said, but there IS deffinately fuel in the tank? |
#24 | |
The spark plugs I took out were dry after trying to start it. What is "chuffing over"? |
#25 | |
Thats the Fuel Pump priming
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#26 |
If the sound lasts about 2 seconds, I know what you mean, and yes, it is priming.
#27 |
Being a pointy and having fuel injection does it have a lot of sensors and voodoo that can stop the bike starting if something has worked its way loose? I don't know anything about the 2nd gen SV but a friend of mine had a sensor fail on his GSXR, was fine until he turned the ignition off.
All I'm suggesting is that if all else fails get someone with the diagnostic software and plug it up and check for any fault codes
"Somewhere between happy and total f**kin wreck" Last edited by Winder; 19-03-12 at 10:46 PM. |
#28 |
Had my K6 failed to start this morning, spins but didn't fire. Suspected it was flooded (fiddled with at weekend) and yep, usual flooded engine clearing procedure worked a treat with FI engine. Fired up in no time after a big pop from the exhaust.
Procedure is open throttle full and press starter, close throttle rapidly when it fires to avoid over-reving
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers |
#29 |
if the plugs are coming out dry, its very unlikely its flooding
you need to try running it with fuel down the plug hole and then decide what course to take from there. there are only 2 sensors that would fail and prevent the engine running- crank position sensor, (which must work as there is a spark) tip-over sensor would kill the spark and injectors and fuel pump (2 of which we know work) Are you certain there is fuel in the tank? are you getting the 'CHEC' display when you try and start it? |
#30 |
The Teacer
Given that it's now 2 days since OP last posted, what's the betting it was the killswitch after all?
There's a fine line between a hobby and a mental illness |
Sv won't start | SUPERSTARDJ01 | Bikes - Talk & Issues | 7 | 14-10-09 09:47 AM |
Wont start, but will bump start :( | Wally | SV Talk, Tuning & Tweaking | 6 | 10-08-07 02:02 PM |
Help! Not sure where to start... | Yokel | SV Talk, Tuning & Tweaking | 5 | 25-01-07 02:48 PM |
She won't start! Help! | Bear | SV Talk, Tuning & Tweaking | 43 | 19-12-06 11:39 AM |
Clocks start spinning and bike wont start?! | lockery | SV Talk, Tuning & Tweaking | 4 | 13-04-06 07:32 AM |
