Old 18-04-12, 01:14 PM   #21
Default Re: Potential pointy Adjuster Plates Group Buy
curvy swingarms are a different profile completely so they would not fit even with a spacer i can look into a solution during the summer if curvy owners are really intrested in something similar.
wow 10 people already. bulk postage is not a problem in fact it's better
liking the idea of the AR Marc.
Old 18-04-12, 01:30 PM   #22
TBH I've not had issues with my plates on my curvy swingarm, I bought some S/S ones from an Ebay seller
They're same dimensions as OEM, just in stainless. Would be real easy to fabricate some I guess, or get stamped out. Depends on the demand
Old 18-04-12, 01:59 PM   #23
Turner
Mine are looking a bit battle scarred - would love a replacement. Count me in
1..joshwalker094....
2..DarrenSV650S.....
3..Epic Monkey......
4..MJC-DEV..........
5..Nobbylad.........
6..muzikill.........
7..The Guru.........Non-Scottoiler
8..The Guru.........Non-Scottoiler
9.. fluffer
10.Kilted Ginger
11. Turner
Old 18-04-12, 02:23 PM   #24
pppfffttt i can have those OEM plates stamped out by the hundreds as i have access to a CNC punch press so they would cost peanuts, its a downstand for a scottoiler i need the dimensions for so i can take it off the top of the left plate and run it under the swingarm. all of which i can have done in shop which costs next no nowt, once the design is in Radan then its just a case of changing a few tooling posts and pressing a button
Old 18-04-12, 02:23 PM   #25
Nobbylad
Nobbylad's Avatar
When are you making them
Old 18-04-12, 02:25 PM   #26
tetol
1 set for me please. Thanks
Old 18-04-12, 02:43 PM   #27
Think I've got the old plates in the garage, can send them to you Bib, if there's enough demand from Curvy owners.
I don't need any though.
Best start a separate thread, as this is derailing yours
Old 18-04-12, 03:04 PM   #28
The Guru
9..fluffer..........
10.Kilted Ginger....
11.Turner...........
12.Tetol............
Old 18-04-12, 03:09 PM   #29
i'll check see if there is any 3mm SS at the workshop first. i would like to get the pointy ones sorted first. but yes i would require the plates to have a look as i found with the pointy ones there is a few things needed to remove the 'slop' and fit properly on the spindle.
Old 18-04-12, 03:10 PM   #30
muzikill
muzikill's Avatar
Sorry to derail but if they already were adapted for a oiler by default i'd be quite happy. The swingarms already got the holes for paddock stand bobbins so why not have a bracket ready for a additional fitment?
2 versions. Oilerbracket version & normal. Youd order 2x normal as a oilerfree version or one of each for the other option.
It will give me another project to get on with, would another oiler system fit onto it or would it be scottoiler only?
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
