#21 | |
As for grabbing a fistful, I've done that once and never again since, smoothness is the name of the game to the point where you can brake gently and comfortably round corners if necessary. |
#22 |
#23 |
I use the engine rather a lot for slowing down, I use the brakes when necessary.
Last month I rode from Halifax to Kirkby Lonsdale in drastic fog, I thought I'd used the brakes a little more than I usually do, as it was adverse weather etc I got there and BluePete said..... 'jeez girl, did you actually brake at all coming here?' My front discs were as rusty as I left them at home. EBCs do that overnight, but the bike hadn't moved for months and it was meant to be a shakedown run! They've been out since, and they are only just clearing I don't use my brakes unless I really need them, either that or they are used very lightly ![]()
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
#24 |
Blipping the throttle makes it so the rear wheel matches the engine speed so the rear doesnt skip (sort of like a slipper clutch), you can also create the desired affect by having your idling speed at about 2000 revs.
These were the tips I got when setting up the SV for track riding by Mike Edwards who helped invent the minitwin series |
#25 |
#26 |
Yes, you will wear the rear tyre faster using a lot of engine braking, than you will if slowing with the brakes. Slowing with engine braking is not a constant braking force, it's on/off/on/off as your pistons go through their stroke, transmitted through the crank, gearbox and chain, to provide a braking force at the back wheel. Pads on discs are a constant braking force.
#27 | |
Never get to the end of a tyre to find out....always get a bloody nail or screw in it way before the treads run in! ![]()
#28 | |
I'm not trying to persuade you one way or another, you can make your own mind up, but the front brake is your most precious friend when riding a bike. You need your brain to apply it in a split second, not slamming on, but forcefully and under control. Its pretty impressive just how hard you are able to brake with the front with a bit of practice. |
#29 |
Thanks for everyone's thought and advice. I'm kind of the opposite to Missyburd. I have a tiny slight phobia of the back brake from locking it up when I was a novice, and do the majority of my braking on the front only. I use the back brake, but haven't really learnt the point at which it locks, so I find a combination of mostly front braking, a gentle amount of rear braking (hardly any) and engine braking feels right at the moment.
I think I'm going to work on that. I'll try and apply more rear brake and get to know the locking point (before I change this tyre!), then try and learn to use it in a reasonable range after that. I'll also have a go at the old blipping. I do that on occasion more for the noise than anything, but need to practice it a bit to make it smooth. Also, yes, I did get a sport tyre. I didn't know they'd wear quicker on the middle. I'll get a touring type next I think. I'm not riding with a vengeance everywhere, so the outside doesnt get enough wear to warrant a sport tyre.
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#30 |
hhmm must just be me that uses both brakes and engine braking but then again i tend to slightly do what people call 'trail braking' when i'm having fun but not to the extreme of keeping them on till the apex. i usually let go just after i tip in. weather it's right or wrong i don't know but heyho. when i'm not having fun and just pootling about i tend to just roll in with a steady throttle.
Clutchless Shifting | Girth | Bikes - Talk & Issues | 34 | 16-05-09 07:50 AM |
smooth shifting | crankcase | SV Talk, Tuning & Tweaking | 3 | 26-04-08 03:46 PM |
Rough Shifting?? | paulc227 | SV Talk, Tuning & Tweaking | 3 | 29-07-07 10:44 PM |
Shifting Problems | Mavfan | Bikes - Talk & Issues | 8 | 13-04-07 02:17 PM |
shifting gears?? | ryrides | SV Talk, Tuning & Tweaking | 8 | 29-12-05 12:02 AM |
