#21 |
Stupid idea.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#22 |
like they said check the spacer and o ring,if all well replace the seal,grease the seal lips before putting in.if you have any play in the bearing or it feals rough and gritty then you will need a new bearing,and i suspect thats a complete engine strip to get at it
#23 |
Pray it isnt the bearing. Its a complete engine strip yes. Doubt it is the bearing though.
#24 |
I will pop to my body shop today and collect some tools and ill strip it back out and have another look.
I'll update later on |
#25 |
Remember when fitting a new seal that the area its sits in is as clean as.
#26 |
what size is the front sprocket nut? just to make sure I bring the right size home
#27 |
#28 |
sorted! happy days!
#29 |
Wrong locknut solution?
Standard front sprocket, bigger rear sprocket, how many more links in chain required? | Holdup | Bikes - Talk & Issues | 6 | 27-02-12 12:40 PM |
Gearbox Oil seal and sprocket lock washer | fig roll | Stuff Wanted | 3 | 09-07-10 04:05 PM |
Front sprocket oil seal | 7755matt | Stuff Wanted | 0 | 30-01-10 04:03 PM |
SV650 front cylinder failure | chewy22 | SV Talk, Tuning & Tweaking | 20 | 27-10-06 07:22 PM |
Oh dear- leak from front sprocket shaft seal? | northwind | SV Talk, Tuning & Tweaking | 12 | 12-05-05 02:47 PM |
