Old 24-09-12, 09:59 PM   #21
Default Re: One for the suspension buffs- Cartridge internals
Well see if you can find out more surely which you should be using.
Ohlins No10 is 22.0cSt apparently.
Viscosity unless you go mental and put 20w in will just change the adjusters range with these differences but should be about rideable.
Any chance I could have an inspect of this kit
Old 24-09-12, 10:20 PM   #22
On the way good man. Bib's will want a nosey as he spotted these
Old 24-09-12, 10:24 PM   #23
is the compression adjuster on the bottom bolt?
Old 24-09-12, 10:34 PM   #24
You looking at the tops?
Old 24-09-12, 10:42 PM   #25
no. rebound is on tops i was wondering how the give you adjustable comp if comp/rebound are on both legs.
Old 25-09-12, 07:53 AM   #26
It is possible that top adjuster adjusts compression.
Old 25-09-12, 08:26 AM   #27
The one with the white spacer is in compression out the box
Old 25-09-12, 08:35 AM   #28
What is diameter of cartridge?
Old 25-09-12, 08:41 AM   #29
Without getting the verniers out about 25mm
Old 25-09-12, 09:21 AM   #30
where are the comp/rebound adjusters located?
Minitwin suspension for curvy (Penske/Cartridge forks) Berlin For Sale - SV's and SV related items 3 14-12-10 10:14 PM
Question for music buffs - Twelfth Night Luckypants Idle Banter 18 03-07-07 02:00 PM
Attention all IT buffs mrs cuffy Idle Banter 12 15-11-06 08:11 PM
New front fork mod - cartridge-like internals Knaapie SV Talk, Tuning & Tweaking 11 06-05-06 09:15 PM
Computer buffs needed Stormspiel Idle Banter 0 25-01-06 10:10 AM
