#21 |
haha, it was £2.75 when i posted that link.
im still to get one, but asked the guy i bought it from and he said he replaced the battery a year ago, and that it might need topping up with distilled water, so I'll give it ago tomorrow night |
#22 |
#23 |
Got my multimeter! So guys this where the fun begins, what tests should I do? And what details do you want
Thanks josh |
#24 |
Firstly, set your meter to dc power setting and test across the battery terminals with engine off, then on, then at high ish revs.
#25 |
Personally I'd skip straight to the Stator test across the 3-pin terminal.
Yours (Phil) was Ka-put, mine was intermittant and Josh's sounds to be going the same way. If you test that and get a flat spot you'll know for sure that the stator is the fault. Its misleading to start from the other end, a stator fault could cause all sorts of misleading problems further along the loom. I think thats why we had this fun with Phil's bike, Tested battery & got it as failing so replaced it... got same results Tested reg-rec, got it as failing so replaced it... got same results Tested Stator, got it as failing so replaced it... BINGO! Start testing at the stator and possibly save your self a new battery and Reg Rec. |
#26 |
That's a fair point matt, the only difference is I was used to using a meter, people who've never used one may find it daunting.
#27 |
Aye too true, an introduction to using the metre might not be such a bad thing.
#28 |
Yeah I have used them before, but years ago. So if you can tell me what setting and any pictures that would be great.
#29 |
battery is in my room, charged it up as it was flat this morning. i checked voltage before it was 12.62 checked it again an hour or two later and it had dropped to 12.57
will check again in morning, see if its lost more. |
#30 |
Was that off the charger I take it?
That's a normal voltage for a battery in rest. You need to put it back on bike and test it again running. |
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? | maxinc | Bikes - Talk & Issues | 5 | 22-07-11 02:59 PM |
Charging the battery | pben47 | SV Talk, Tuning & Tweaking | 19 | 09-02-10 06:56 PM |
Battery charging and tank raiser questions. | allantheboss | Bikes - Talk & Issues | 14 | 03-02-10 02:58 PM |
Charging the battery | SV PILOT | Bikes - Talk & Issues | 7 | 31-03-08 05:05 PM |
Charging/Battery: | MrMessy | Bikes - Talk & Issues | 8 | 30-11-07 12:50 PM |
