Old 05-01-13, 01:08 AM   #21
LewSpeight
LewSpeight's Avatar
Default Re: What's my best option for HID?
Yeh thats probably a good idea.
Am i pretty much foolah'd if it doesnt?
Old 05-01-13, 01:12 AM   #22
You could just completely remove the light units reflector and just mount the projector another way
Old 05-01-13, 01:13 AM   #23
musne
Originally Posted by LewSpeight View Post
Sounds easy enough. Im really thankful for your help! I've been struggling to find any information like anywhere haha
When you say 'rotate to get a straight beam', how dya mean? I get the impression that you can spin the front of the glass and it changes the beam pattern or whatever?
I know i know, i'll shut up.
You're welcome buddy, you'll find it a lot more straight forward when you get your hands on it.
Yes, the whole thing is like a big sphere/cylinder, once it's attached you can rotate it a little to get a perfect straight line (not so much a pattern, but just the angle of the line).
Old 05-01-13, 01:24 AM   #24
LewSpeight
LewSpeight's Avatar
I like it... Any ideas on how? Just mold a big circular dome or something?
Old 05-01-13, 01:26 AM   #25
I'd incorporate it in to the headlights mounting brackets. Just a big O with two sticks on it
Old 05-01-13, 01:22 PM   #26
LewSpeight
LewSpeight's Avatar
How close can the projector be to the front of the headlight unit before it'll start melting it?
And how long do I do this oven thing for to get INTO the unit?
Old 05-01-13, 09:12 PM   #27
leebex
I used a heat gun (the paint stripping black and decker type) to seperate my curvy headlight when I fitted the projector unit)
tried the oven method and it didnt work so used the heat gun but you have to be careful as the plastic will soften if you go too mad.
Old 06-01-13, 12:31 AM   #28
musne
Leebex, you probably didn't oven yours for long enough or hot enough.
Mine was in the oven for around 10 to 15 minutes on the highest temperature settings and it came off with ease. Maybe too easy as the glue started to stretch and fly everywhere! :O
So a tip for you from my experience. When separating the the plastic housing from the plastic lens, do it a little at a time and do it gently too, don't go pulling like mad like I did.
Old 06-01-13, 12:32 AM   #29
musne
The projector unit gets hot, but not at temperatures high enough to start melting the headlight lens.
Old 11-01-13, 11:43 PM   #30
LewSpeight
LewSpeight's Avatar
Okay. So the actual depth of the inner headlight unit is 8cm, I need 9cm for the hid projector so it won't fit. Any ideas? Here is it mounted with standard bulbs.
Also, any ideas on what to do to wrap up the wiring loom properly and make it look tidy? Or atleast ideas of covering up the sides? I can see right through from one side to another with about an inch or two gap behind the headlight revealing all the wires.
Can't move it closer because of the massive speedo!
BMW finance an option, hmmmmm... etuna Bikes - Talk & Issues 10 05-08-09 10:28 AM
Another helmet cam option. northwind Bikes - Talk & Issues 9 26-10-08 11:06 PM
Is a cut exhaust the best option? webgeeze SV Talk, Tuning & Tweaking 29 15-06-07 08:52 PM
The nuclear option... northwind Idle Banter 79 02-07-06 06:24 PM
Is the SV considered a soft option? pegasus Bikes - Talk & Issues 45 22-01-05 03:11 AM
