#22 | |
it has brought the same battery back from death (0 power and on the red light) twice. ok so it took a cppl days but it works lovely. |
#23 | |
first one lasted about a year. you only find out id has failed when you need it. So stupidly bought a second. After a further year, lesson learned I bought an optimate.
Not Grumpy, opinionated. |
#24 |
Just ordered the optimate. Thanks for all your help!
#25 | |
![]() so if it breaks then no loss. the Ctek from Aldi i had (sorta still do) is much better. |
#26 |
I bought an Optimate in 1999.Still got it.Still working.Bargain.
#27 | |
My Optimate standard plug peeks out from under the seat so plugging in after a ride is simplicity itself. Good piece of kit which has lasted me for years.
We are the Goon Squad and we're coming to town, BEEP BEEP! |
#28 |
Hey so I've got the optimate 4, changed it to can-bus mode and connected it all up (with the manufacturer lead) to the 12v cigarette socket on the bike. It has been flashing on the initial stage (detecting a signal) for about 20 minutes and I wondered how long it takes to detect? Thanks!
#29 | |
#30 |
A can-bus fag lighter? Yewhat?
Pointy isn't that clever. If your 12v is live permanently then just plug it in with whatever setting you'd connect it to the battery.
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? | maxinc | Bikes - Talk & Issues | 5 | 22-07-11 02:59 PM |
dead battery - possible reg/rec + battery? | collis | SV Talk, Tuning & Tweaking | 8 | 20-09-10 02:47 PM |
Optimate battery charger drains the battery | flymo | Bikes - Talk & Issues | 10 | 10-06-09 10:41 AM |
Battery/Starting problem - new battery hasnt fixed it! | Aaron | SV Talk, Tuning & Tweaking | 13 | 24-01-05 05:21 PM |
