Old 19-10-15, 06:27 PM   #21
Default Re: Water/oil cream in crankcase.
Originally Posted by panku View Post
. Now the hose out of the water pump is blocked with a screw(maybe done by former owner) so all the water gets dumped in the case. In fact I think the mixture is more water than oil. Work on the bearing and change the oil (obviously) and bike feels fine.
Do I need to start thinking of getting another water pump?
Thanks
eh? A screw blocking the outlet hose? Are you mistaking it for the coolant drain plug?
if the outlet was blocked, then the coolant wouldn't circulate round the system.
if the bearing are shot, then the seals would be shot too, i cant remember if the pump has a telltale hole. I suspect it doesnt, and thats why its leaking coolant into the crankcase.
Old 20-10-15, 12:41 PM   #22
Corny Gizmo
I think your very lucky it hasnt caused any obvious damage!
Old 22-10-15, 01:47 PM   #23
Wonder how my engine survived that abuse. Is there anything else I"m supposed to do to make up for the abuse I put it through?
Thanks
You may as well stick another pump on it or just rebuild yours, no real difference.
Nothing you can do for the engine other than change the oil, run it for a while then change it again to get any residual water out. Maybe when you put the first oil in, crank it with the spark plugs removed to get oil circulating first (until oil light goes out).
If it goes bang it will go bang, probably big ends. Nothing you can do about it now though just see how you go on.
Old 22-10-15, 03:40 PM   #24
ophic
ophic's Avatar
I think you should prepare for this eventuality by videoing it
Silver SV650SK3, Fuel exhaust
Old 23-10-15, 09:28 PM   #25
Nothing that spectacular to be honest, generally fine then "knockknockknockknock" "wtf's that" followed by emptying the brass sludge out with the oil that used to be bearing shells.
Crankcase Problem orgilbert1 Bikes - Talk & Issues 2 15-02-12 01:06 PM
Crankcase ventilation - how much is too much? Troy SV Talk, Tuning & Tweaking 3 14-04-10 06:40 PM
Crankcase Reassembly squirrel_hunter SV Talk, Tuning & Tweaking 6 26-02-10 05:36 AM
Crankcase breather andyaikido SV Talk, Tuning & Tweaking 2 05-09-06 06:28 PM
crankcase and water pump auldyin Bikes - Talk & Issues 2 09-07-06 09:39 AM
