Old 16-06-13, 06:30 PM   #21
stuR
Default Re: Continuing battery problems.
Just sounds like your battery is fubared. They dont like staying flat, ive had a batteru die that was being charged with a battery charger once a week just suddenly die. Ive also had one completely dead the day after it had a long drive and therefore should of had a charge, but it just gave up the ghost randomly.
Old 17-06-13, 09:55 AM   #22
aesmith
Did you ever check that whether the battery holds its charge if it's disconnected from the bike?
Old 17-06-13, 09:59 AM   #23
dirtyred619
Thats a good shout. I'm gonna take another set of readings later on then I'll disconnect it and see how I go.
Old 17-06-13, 02:31 PM   #24
ethariel
ethariel's Avatar
Have a look at the wiring on the back of the fuse holder, my S3 had issues with the battery dying all the time and it was a corroded wire on the back.
ethariel is offline   Reply With Quote
Old 17-06-13, 02:54 PM   #25
dirtyred619
I'll have a check and see thanks.
Here's todays readings:
Off: 12.95
Bike On: 14.48 approx.
5,000 RPM : 14.48 approx.
I've now disconnected the battery and I'll take regular readings this week. One thing that is a slight concern possibly is that after I unhooked the battery and took a reading it was 12.98, .03 higher then when connected but off. Could that indicate that there is a slight drain or is that negligable?
Old 17-06-13, 03:06 PM   #26
dirtyred619
Just had a check all looks good thankfully.
Old 17-06-13, 03:38 PM   #27
dirtyred619
Sorry for spamming!
As I'm bored and after doing a bit more reading I've just tested the battery voltage again and its now 12.74v. Also, I've reconnected the postive lead and and ran the multimeter between the negative terminal and negative wire. I beleive this should be 0 if all is fine but just got a reading of approx. 11.4v. Battery?
Old 17-06-13, 04:09 PM   #28
Pete7
Pete7's Avatar
What does it read with the ignition switched off?
Pete
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 17-06-13, 04:40 PM   #29
dirtyred619
Pete
Thats with only positive lead connected and ignition off sorry.
Old 18-06-13, 08:18 AM   #30
dirtyred619
12.67 this morning.
Battery problems sonicated SV Talk, Tuning & Tweaking 6 01-03-11 03:33 PM
Anyone had problems with Battery? Springbokki SV Talk, Tuning & Tweaking 2 30-06-09 09:55 AM
Battery Problems SV Meldrew SV Talk, Tuning & Tweaking 9 04-02-09 10:54 AM
Battery problems gerbrox Bikes - Talk & Issues 4 21-08-08 12:31 PM
Battery Problems Dom_ SV Talk, Tuning & Tweaking 7 19-06-05 10:10 AM
