Old 12-07-13, 09:54 AM   #21
flymo
flymo's Avatar
Default Re: Bike rebuilt but no power?
Does the clutch switch actually work? Also I think its a normally open switch, so you can disconnect the clutch switch and short the two connectors for it on the wiring loom side using a paper clip or similar. That will eliminate the switch while you troubleshoot. Also check the same for the sidestand switch.
Old 12-07-13, 10:01 AM   #22
Mauler
Mauler's Avatar
Bridge the two clutch switch connections and see if it works then?
Gah, beaten to it!
Mauler is offline   Reply With Quote
Old 12-07-13, 10:08 AM   #23
Kwally5
Will give it a go 1 minute
Old 12-07-13, 10:12 AM   #24
Kwally5
Hi. Still not working with thw bridged : / anyone close to hwlp me. I will pay lol
Old 12-07-13, 12:18 PM   #25
flymo
flymo's Avatar
where would that be?
Old 12-07-13, 12:20 PM   #26
Kwally5
I live in Atherton, near to Bolton/Wigan/Westhoughton if anyone can help
Old 12-07-13, 01:09 PM   #27
wideguy
Can you hear the starter relay click when you push the starter button?
There's a pretty good troubleshooting chart in the maintenance manual- it would be best to get one and follow it. There's lots of interconnected stuff in the starting circuit- sidestand switch, clutch switch, kill switch, ignition switch, starter relay- all of it has to be properly connected and operating for power to be sent to the starter motor, which also has to be properly connected and working.
Old 12-07-13, 01:46 PM   #28
Kwally5
I cant hear the starter relay kick in.
And i will take a look. Cheers
Old 12-07-13, 06:30 PM   #29
Kwally5
Okay so I put a spanner on my fuse box from + to - and the bike turned over so I am loosing power before it gets to that area. Going to have to check my wires i'm guessing.
Calipers rebuilt, still dragging a bit. Fowlersrs Bikes - Talk & Issues 10 08-04-13 05:41 PM
RGV 250 Rebuilt to as new danf1234 For Sale - Other Bikes and General biking items 20 09-08-12 01:37 PM
the rebuilt sv (photo heavy) davepreston Bikes - Talk & Issues 12 12-06-09 01:02 PM
Rebuilt and back on the road Lozzo SV Talk, Tuning & Tweaking 0 29-02-08 06:43 PM
Rebuilt me forks Grinch SV Talk, Tuning & Tweaking 4 20-06-07 08:07 AM
