Old 05-08-13, 09:21 AM   #21
Corny Gizmo
Default Re: Bike not starting after ride, now wont start at all
ok ill try again when i get back, before i take it to the garage
so if i dont get voltage on one of the 3 phases does that mean i probably need a new geny? (provided the wiring is ok)
Old 05-08-13, 09:26 AM   #22
rictus01
rictus01's Avatar
provided the wiring is OK inside the alternator cover as well, then yes it probably
Old 05-08-13, 10:24 AM   #23
Corny Gizmo
ok mate, thanks for the advice - mucho appriciado!
Old 05-08-13, 12:18 PM   #24
Corny Gizmo
hi all,
im getting around 80 AC Volts from all three phases @5K revs, at the connector to the rectifier, iv only just bought the R/R so im stuck (it has the direct to battery mod to)
if it helps the yellow wires are warm
Old 09-08-13, 07:34 AM   #25
Corny Gizmo
morning all, update.
so far ive replaced the solenoid, the RR and now the battery.
all was going well yeterday, plenty of cranking power from the new battery, started it today all good. got about 8 miles down the expressway and the rev counter died at around 50MPH and the petrol light came on solid (full tank) then it went normal again, 5 seconds later rev counter died again, fuel light on and the bike began to stutter as if it had no fuel. It died at the side of the road, i bumped it but then it died again soon after (no lights on the dash) i wiggled the wires on the solenoid and the lights came back on. but still no cranking power and it eventually dies if bumped (usually braking kills it)
in the end i pushed it to work and now once again im clueless. im guessing its a loose wire/short, given the clue of the rev counter diying first does anyone have a decent idea?
thanks guys
Help!! Bike wont start Brad SV Talk, Tuning & Tweaking 5 27-04-11 06:15 AM
bike wont start, help! stanie SV Talk, Tuning & Tweaking 15 31-03-09 09:39 PM
Bike wont start. I Need help please chunkytfg SV Talk, Tuning & Tweaking 3 13-03-08 11:53 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
My bike wont start - why? SV Ste SV Talk, Tuning & Tweaking 6 01-12-05 08:23 PM
