#21 |
Lots of engines have a "dead spark" at the bottom of the cycle, so actually fire the plugs twice per full engine cycle. It's easier to engineer this, than have another sensor on the cam to decide if the engine is actually on the compression/ignition stroke.
#22 | |
650 doesn't have a cam position sensor, 1000 does.
#23 | |
How does the ECU when initialised know which stroke is firing and which is intake? It senses the suck as it needs to inject fuel on intake, not on power stroke. No point making a super environmental high-pressure super atomising uber lean burn system... and then gobbing fuel onto the back of a closed valve is there!
#24 | |
And throttle bodies themselves are pretty bombproof... it's all the other crap attached that can be problem. Throttle position sensor is massively important, so is STV servo and STV position sensor, injectors etc.
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 15-10-13 at 07:46 AM. |
#25 | |
If the injected 650 doesn't have a cam position sensor, how does it know when the intake valves are opening? When you say it "senses the suck", that implies that the MAP sensor provides the information for injector opening timing. That seems pretty imprecise. |
#26 |
MAP sensor would give which-stroke-are-we-on info, exact engine position is given by the crank pickup.
#27 |
this might help
#28 |
Thanks Sid, crank position sensor works for me for the basic when precisely to start delivering fuel question.
#29 | |
Works for me too!
#30 |
SK6 Throttle Bodies Synchronisation? | Chris Bird | SV Talk, Tuning & Tweaking | 9 | 20-07-12 08:51 AM |
throttle bodies 07+ | svsam | Stuff Wanted | 0 | 29-04-12 06:59 PM |
bored throttle bodies | prilpot | Stuff Wanted | 1 | 08-11-11 11:49 AM |
Bigger throttle bodies | ThEGr33k | Bikes - Talk & Issues | 32 | 18-07-09 06:10 PM |
ANOTHER set of throttle bodies..? Please no... | Bluewolf | SV Talk, Tuning & Tweaking | 6 | 08-06-09 09:28 PM |
